09-02-2014, 10:27 AM | #1 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Car should dyno this week, anyone want to guess what it does..
My car is finally finishing the second stage of the latest round of upgrades. It will be on a dyno this week!
Through this summer ADM went through my ERL block, bored it to 434 cubic inches and we put on the Heartbeat blower. Mid July I drove it out to Arizona and AGP turbo began adding twin precision 6466 turbos. He has done a lot of testing and it is very hot in Arizona, keeping the intake temps down when ambient is around 110 is a tall order. This will be the first compound boost ZL1. Just a highlight of some of the testing. With the blower set to run 11 pounds of boost and the turbos supplying only 5 pounds of boost into the inlet tube, the intake boost pressure is 20 pounds. It really does compound 11+5=20. From a second gear roll at 1500 rpm at zero boost, when the throttle is pegged open the data logs show the car has 10 pounds of boost in .5 seconds and the full 20 in one second. Full boost is available before 2500 rpm, at least with boost only set to a max of 20.... So any guesses on what it will dyno?
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
09-02-2014, 10:55 AM | #2 |
1250/1250
I honestly have no clue, but I can't wait to see the results. You bring a lot of good info to the forum and have such an amazing car. Good luck.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
09-02-2014, 11:10 AM | #3 |
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS Join Date: Jul 2010
I just wanna drive it.
Currenent rides: 2020 SW ZL1 A10 2019 SW 2SS A10 2017 SW Silverado LTZ |
09-02-2014, 11:22 AM | #4 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
1157/1205
09-02-2014, 12:07 PM | #5 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I'm glad you're on team ZL1
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
09-02-2014, 12:52 PM | #6 |
Drives: 2013 ZL1 Ashen Gray Join Date: Oct 2013
NASA called they want their space shuttle back.
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience. 754 RWHP 747 RWTQ 93 Octane http://www.camaro5.com/forums/showthread.php?t=347243 |
09-02-2014, 01:17 PM | #7 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
HP, TQ
That car will be as crazy as you! Good luck |
09-02-2014, 01:27 PM | #8 |
Drives: none Join Date: Aug 2011
What fuel? At the 20psi its at now?
09-02-2014, 02:24 PM | #9 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
1155!
09-02-2014, 02:27 PM | #10 |
Drives: 2017 ZL1 A10 Join Date: Sep 2009
1185
2017 ZL1
A10 Redhot with stripe |
09-02-2014, 06:08 PM | #11 |
Speed Freak
First thanks for all of the warm wishes. I'm just hoping I don't blow another engine on the dyno.
All testing to this point has been done on 91 octane pump gas with very conservative timing. Heat has been a real problem because of the warm weather when the ambient is 110 and the location of air filters on the turbos is drawing air off of the hot sun baked blacktop, IAT 1 has been as much as 135. That puts IAT 2 at 150 to 160 without getting into it much. Dyno testing will be done with 100LL aviation gas. I carried a tune for it and ran a lot of AV gas previously. Change the O2 sensors regularly and it is fine. Will most certainly do dyno pulls with ice in the supercharger reservoir and still monitor IAT 2. With ice in the reservoir I think IAT 2 should be fine through a dyno pull. The car dynoed, 725 on just 11 pounds of supercharger boost before the turbos were added. Tried some different pulley combos and at least for now decided that 11 was the sweet spot on the supercharger at least only running it up to a total of 20 pounds compound boost. This pulley ratio is keeping the supercharger around 19,000 rpm or less throughout the engine rpm limit. Less supercharger boost produces slightly lower intake temps but it takes a lot longer to build boost. When I have numbers I'll let you guys know shortly thereafter....
09-02-2014, 06:16 PM | #12 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
1200hp 1150tq
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
09-02-2014, 07:05 PM | #13 |
Drives: 2015 SS Sedan M6 Join Date: Dec 2009
thee fitty
09-02-2014, 07:31 PM | #14 |
SLOBRA1
Drives: GT500/Cruze/DMax/Cobra Join Date: Feb 2012
964.335whp
Hope it goes well for you on the dyno!
2010 GT500 Best ET=10.10 - Best Trap=143.59mph
2003 Turbo Cobra Best ET=8.27 - Best Trap=166.42mph |
