Old 07-21-2012, 06:19 PM   #1
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
question concerning rear height?
hi.
i decided to measure the height of my camaro by the way peddlers measures bottom lip of rim to top of fender arch going up the middle of rim. My car measures 27in all around but not my p/s rear it measures 27 1/2 inches. sorry i didnt measure in mm. i was wondering why my rear p/s is higher. i have upgraded trailing arms, full poly subframe bushings, a rear balance bar and i installed 2012 rear shocks from SS a while ago.
i visually inspected the subframe and all look normal but the p/s front subframe bushing lip is slightly bent up prob. due to supporting the car w. a jack.
Is my car good. im a bit over anal with my chevy. Suspension Gurus please chime in.
thanks joey
chopss is offline   Reply With Quote
Old 07-21-2012, 06:38 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
The subframe bushes are stiffer than OEM, thus raising the back end of the car some. Nothing to worry about though
Click to view my build thread
Old 07-21-2012, 06:48 PM   #3
chopss
chopss's Avatar
thanks for the response stieger
so its ok if the p/s rear is a 1/2 higher than d/s rear?
Old 07-21-2012, 07:09 PM   #4
The Stig
The Stig's Avatar
Yep. Though if your really worried you could put the car on a lift and check to make sure the springs are seated properly.
Old 07-21-2012, 08:31 PM   #5
chopss
chopss's Avatar
thanks you for the response. puts me more at ease.
Old 07-21-2012, 08:34 PM   #6
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
i would check that the springs are seated as he said,
which springs did you install?
Info@PeddersUSA.com is offline   Reply With Quote
Old 07-21-2012, 08:37 PM   #7
chopss
chopss's Avatar
the springs are stocks from a 2012 SS
Old 07-21-2012, 08:38 PM   #8
Info@PeddersUSA.com
could just be variation in the springs,
i believe that the OE springs have a 13mm tolerance.
Old 07-21-2012, 08:56 PM   #9
chopss
chopss's Avatar
thank for the replys
i was just worried
