#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
AWE Tuning
Old 11-13-2022, 06:38 PM   #1
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
M&H or Hoosier bias ply fronts with MT Et street R on the rear
How do M&H or Hoosier bias ply front runners mix with the MT ET street R which are a radial construction just down the 1/4 mile. I will never run the set up on the street. My car traps 120-122 and with the OE stock front wheel/tire it tracks straight.
lt4camaro is offline   Reply With Quote
Old 11-13-2022, 09:14 PM   #2
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I would run the MT Bias up front and Rs in the rear. I have run the MH and they are fine also, ran them on my C7. I've run the Hoosiers but don't like the way they balloon out on the wheels. Wouldn't recommend them. I run the 27.5x4-17 M/T, they balanced well and only weigh 12 lbs.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 11-14-2022, 08:20 AM   #3
lt4camaro
lt4camaro's Avatar
So you have had or heard of no ill affects mixing the bias ply front runners and the radial construction MT ET street R drag radial. Where did you get a 17inch front runner skinny wheel to fit the 6th gen? all I see are 18 inch wheels and tires for the front of our cars.
Old 11-14-2022, 09:29 AM   #4
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
I will say, I ran a radial up front and Bias ply rear and it was a nightmare. Rear was walking all around. Not sure how the opposite way would go with Radial in the rear and bias upfront. For me after that, I always ran Radials all the way around.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 11-14-2022, 10:35 AM   #5
laynlo15
laynlo15's Avatar
Ron is right, many have tried what he did and it's unstable. I ran Bias on my 16 for a few year with Radial on the back and no issues. The reason I ran the Bia on the front was the weight difference in the bias and radial is well over 12 lbs each and that makes a difference on weight transfer and rolling mass.
Old 11-14-2022, 05:45 PM   #6
TOSTO RACING
STOCK ELIMINATOR
TOSTO RACING's Avatar
Drives: STOCKER
I run bias up front radial in the rear drives like a new car!
5664 AA/SA
1970 NOVA
TOSTO RACING is offline   Reply With Quote
Old 11-14-2022, 05:55 PM   #7
lt4camaro
lt4camaro's Avatar
Hey Greg, can you comment on what 17inch front skinny wheel you use. I see nothing for the 6th gen.
Old 11-14-2022, 05:55 PM   #8
lt4camaro
lt4camaro's Avatar
Thank You
Old 11-14-2022, 05:57 PM   #9
lt4camaro
lt4camaro's Avatar
Thank you.
Old 11-14-2022, 06:04 PM   #10
lt4camaro
lt4camaro's Avatar
Hey Layinlo, sent a note out to Jannetty racing my tuner about adding a few degrees of timing up to about 3500 rpm and leave the remainder of the tune alone and he said he would not unless he sees some data. Personally I feel adding a few degrees of timing starting at 1500 up to 3500 shouldnt hurt anything or cause detonation considering he tunes conservatively. Can that be done ? or am I wishful thinking
Old 11-14-2022, 06:08 PM   #11
lt4camaro
lt4camaro's Avatar
And you have a car in a much faster league that traps much higher MPH. I feel good about that.
Old 11-15-2022, 07:05 AM   #12
laynlo15
laynlo15's Avatar
Mine are the RC Bandits, 17x4.5 (15.8lbs) with 27.5x4-17 MT front runners. (12lbs bias), Rear are 17x10 with 7.25 bs and they weight 19 lbs.
Old 11-15-2022, 07:09 AM   #13
laynlo15
laynlo15's Avatar
We were running about 18 degrees of launch timing on my NA tune. Now we are running about 9 degrees on my Maggie launch tune.
Old 11-15-2022, 08:18 AM   #14
lt4camaro
lt4camaro's Avatar
Thank you. The 17 inch front wheels have no problem clearing the brakes , that is news to me. They are a 120 bolt pattern and not a 120.6 correct. BTW, your current set up rear Hoosiers are radials I assume.
