#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
Old 05-02-2023, 08:03 AM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
ET Street R Air Pressure
How low can I go at the strip? 14, 15, 16?
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is offline   Reply With Quote
Old 05-02-2023, 09:08 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I am guessing 16-18psi. Slicks you would run lower but I don't think a drag radial would like it.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 05-02-2023, 01:10 PM   #3
JSH
JSH's Avatar
Drives: '20 ZLE
I've been running them around 16 lb. Maybe 15 and a half because my air gauge is old and reads a little low so 14 and 1/2 equals 16 lb
'20 ZL1 1LE A10,
Old 05-02-2023, 03:06 PM   #4
Sillysspeed
Drives: 98 Camaro
Heavier car on a good track you should be 18-20psi
Sillysspeed is offline   Reply With Quote
Old 05-03-2023, 06:53 AM   #5
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I talked to MT techs at Alanta Tvs shootout a few years back and they told me 19 to 20 psi since the car and driver was 3900 lbs. That's about where I ran the Street Rs all season long. I run my Hoosier slicks at 15 psi on my Lt1 Camaro.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 05-03-2023, 08:12 PM   #6
Choda
Drives: Turbo 6.2
I set mine to 18 cold. I bet they gain a lb or 2 after burn out.
17”
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 05-03-2023, 08:22 PM   #7
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
17”
I ran my 17” beadlocks the same way.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
Joshinator99 is offline   Reply With Quote
Old 05-03-2023, 08:29 PM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
All five of my hits have been at 16#
'20 ZL1 1LE A10,
Old 05-03-2023, 08:30 PM   #9
ShockingZ
Drives: Chevy Camaro ZL1
I never go that low. 24-26 usually. Do a burnout to first smoke then drive it out. The car will hook. No need to go that low at all.
ShockingZ is offline   Reply With Quote
Old 05-03-2023, 09:26 PM   #10
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Cold 15#s. Have gone 1.31-1.34 60ft on a handful of passes.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 05-03-2023, 10:09 PM   #11
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
When I ran ET Street R’s it was around 22. That is where we’ve been on the Radial Pro’s also. We recheck at every pass - going into and while in the lanes if it’s hot and sunny.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 05-04-2023, 04:06 PM   #12
JSH
JSH's Avatar
Drives: '20 ZLE
What pressure would you run 305/45R17 at on the road?
'20 ZL1 1LE A10,
Old 05-04-2023, 04:20 PM   #13
Hammer-joe
Drives: 18 Camaro 2SS
Tire pressure
18 track 32 street
Hammer-joe is offline   Reply With Quote
Old 05-04-2023, 06:32 PM   #14
JSH
JSH's Avatar
Drives: '20 ZLE
I put 30 in them before leaving the track
'20 ZL1 1LE A10,
