07-06-2013, 10:53 AM | #1 |
Drives: Black Camaro 2SS/RS 1LE Join Date: Jun 2011
Chemical Guys foam gun soap?
I know in the past I have read a few positive reviews about Chemical guys Honeydew Melon foam soap, BUT does anyone have up to date personal experience? Thanks!
07-06-2013, 11:14 AM | #2 |
I like teeth.
Drives: #198 Join Date: Oct 2009
just use maxisuds. Will get you the same or similar performance for a fraction of the cost.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
07-06-2013, 11:16 AM | #3 |
Banned
Drives: 2010 2SS/RS A6 & 2011 1LT/RS Join Date: Apr 2012
Yep use maxisuds. Just makem sure you use a quality foam gun. The chemical guys foam gun sucks. I bought a Gilmore industrial gun off amazon and it foams sooooo much better than the CG piece of crap.
07-06-2013, 11:17 AM | #4 |
Drives: ... Join Date: Apr 2009
Honeydew is a great soap although it does not have the suds I prefer, but does cling very well. What I have found is if you mix honeydew with maxisuds II it foams great and clings very well.
CG UK has a snow foam that is amazing but you have to import it. This stuff foams great and has around a 4 minute cling time in the sun without drying. With that said, for the money honeydew is good. |
07-06-2013, 03:41 PM | #5 | |
I like teeth.
07-06-2013, 04:13 PM | #6 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Which one did you have? Gilmore makes many of the guns out that that other companies put their names on. CG has two foam guns for water hoses and one of them is a Gilmore.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
07-06-2013, 04:46 PM | #7 |
ROAD COURSE JUNKIE
07-06-2013, 05:49 PM | #8 | |
Search Ninja
07-06-2013, 06:04 PM | #9 |
I hasn't tried UK Valet's cherry snow foam. However if you really want to try one of the best snow foam then you have to give Valet Pro pH neutral a try. This stuff sticks on like paint, also works good on a pump sprayer too.
