Old 09-01-2010, 10:50 AM   #1
Holis
Drives: 2014 2SS Convertible
Will 1 7/8" Kooks headers pass inspection?
Wodering if these headers will pass inspection
Holis is offline   Reply With Quote
Old 09-01-2010, 12:34 PM   #2
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
As long as your not throwing codes you will.
justa25thTA is offline   Reply With Quote
Old 09-01-2010, 03:32 PM   #3
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
In texas I don't believe they do a visual .. if you don't throw a code you should be fine. However if in the future you move to a state that does visuals as well (or if texas adopts it), then I don't believe you will pass ..
Crowley
Crowley is offline   Reply With Quote
Old 09-01-2010, 03:35 PM   #4
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
+1 I passed, here in PA
Black 2SS RS LS3 Inferno Int. '17 1LE replica 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Ideal performance upgraded clutch master cylinder:Tick performance upgraded slave cylinder/throwout bearing: Mantic 9000 twin disk clutch & light weight flywheel: Tuned by Doug Ring at ECS. 475RWHP/445RWTQ.Dynapack Dyno.
MrGazinya is offline   Reply With Quote
Old 09-01-2010, 05:06 PM   #5
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '20 Corvette Stingray
As long as all the sensors were installed, and you aren't throwing any codes.....you will be fine. A few of the guys in our club are running them and they pass with flying colors.....and they live in one of the strickest countys in the state.
Old 09-01-2010, 07:12 PM   #6
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
I checked with my inspection place and they said that as long as Cats are installed doesn't matter.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 09-02-2010, 06:53 AM   #7
Sir Nuke
Sir Nuke's Avatar
BINGO!!
Old 09-05-2010, 10:11 AM   #8
crussell83
SS Gimp
Drives: 2ss SS/RS IBM
Send a message via AIM to crussell83
have these headers on my car with no cats and i pass...as long as your not throwing a code and your check engine light is on your fine...had the same setup on my vette with no cats and it passed as well
2010 SS/RS 2ss Imperial Blue w/White stripes
Airaid Cold Air Intake, Kooks 1 3/4" Longtubes, Kooks X-Pipe, Borla Stinger mufflers, Custom Tune, Eibach 1" Lowering Springs, TSW Vairano Rims
Lots more to come
crussell83 is offline   Reply With Quote
Old 09-05-2010, 11:23 PM   #9
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
I do state inspections and by law cats are required. A visual inspection is supposed to be done by the inspector to check for the presence of cats and various other emissions items. The law also states that whatever emission components came with the car originally, they're supposed to be there Cats are supposed to be checked visually on year models 1984 and up. If you have a pre 96 vehicle that requires the dyno and sniffer test there is no way you will pass the test. If your vehicle is 96 and up year model then it will fail if the check engine light is on as stated above. So if you dont have cats, you will fail the visual inspection. Does anybody do the visual inspection for cats? Not likely So, in short, You will fully pass the state inspection if you have headers, cats, and no codes.
Hope this helps, jrrod.
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 09-05-2010, 11:24 PM   #10
do high flow cats pass inspection?
Old 09-05-2010, 11:28 PM   #11
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
In Texas they will as long as you dont have codes or check engine light is on.
Old 09-07-2010, 11:18 AM   #12
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
When you tune out the CEL do they dissable the rear sensors, or is it something different? I'm just wondering because if they hook up the PC it will show NOT READY and you fail correct? I'm wondering if most tunes will correct this and you will be good to go. I doubt the places will check to see if the cats are there when the car is a couple inches off the ground and very diffucult to see in the first place. Also, I've heard that even high flows will pass the sniffer test. Obviously we are a long ways away from being required (post 96'), but just wondering.
ackeight is offline   Reply With Quote
Old 09-07-2010, 11:44 AM   #13
Duke
Duke's Avatar
Drives: 2010 Red SS/RS
The tuner sets the rear O2 sensors to the permanent READY state. So, they aren't technically disabled.
Duke is offline   Reply With Quote
Old 09-07-2010, 09:01 PM   #14
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Awesome Thanks!
Kooks Custom Headers Cruise-in and Dyno Shootout ukalumni93 5th Gen Camaro SS LS LT General Discussions 6 06-21-2010 01:23 AM
Kooks Headers from Maryland Speed alfie43 Vendor and Seller review / feedback / experiences 24 03-01-2010 12:23 AM
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 06:46 PM
My SS is at Kook's right now getting headers and high flow race exhaust and X pipe Badger Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 83 06-30-2009 12:22 PM
