Old 09-24-2018, 04:31 PM   #1
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
First track run
Well first track run went ok. Few things to work out in tune and my exhaust think full exhaust with mufflers might be holding me back. But Ran it at 18lbs boost but will turn it up next track run see what we can do.
Full stock suspension minus rear lower control arms and toe links
1fast is offline   Reply With Quote
Old 09-24-2018, 05:19 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Is it front wheel drive? 150mph and 9.5 seconds the first time....nothing short of unbelievable
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 09-24-2018, 10:09 PM   #3
agent5
Drives: 2013 Camaro SS (+RS) + Hurst+ DME
That's most impressive! I had just a bolt-on i1 Procharger and did horrible on my run and got a 12.00, I've since put some long tube headers, a D1 at around 10PSI, BMR toe rods, poly bushings and some upgrades to the suspension and plan to take the car on Wed. But I'm honestly only expecting 11's.. but your car.. awesome..
agent5 is offline   Reply With Quote
Old 09-25-2018, 03:24 AM   #4
1fast
1fast's Avatar
Drives: 2010 Gen 5
What tires are you running
Old 09-25-2018, 07:41 AM   #5
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
What wheel tire combo did you have on the rears for the run?
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 09-25-2018, 08:14 AM   #6
1fast
1fast's Avatar
Drives: 2010 Gen 5
Skinnys on front. Factory rims rear with mickey et on rear with 14 psi tire pressure. Track prep was for radial
Prep. 150 ft out.
Old 09-25-2018, 10:44 AM   #7
Taylortoons
That’s amazing. My ET Streets are like driving on ice with oem ZL1 rims. The ET R on 18 reps hooks up pretty well.
Old 09-25-2018, 11:36 AM   #8
agent5
Continental DW's.. It's my daily driver so I know they are not the best for track stuff but they are surprisingly well balanced. What do you have?
Old 09-25-2018, 12:08 PM   #9
1fast
1fast's Avatar
Drives: 2010 Gen 5
[QUOTE=Taylortoons;10320842]That’s amazing. My ET Streets are like driving on ice with oem ZL1 rims. The ET R on 18 reps hooks up pretty well.[/QUOT
Are you supercharged or na. My et work amazingly even better on street
