Old 10-10-2012, 07:45 PM   #99
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Originally Posted by caverman View Post
Ok....so I'm going to be upgrading my rear suspension to the FE4 version. I haven't seen any kind of DIY on it yet so I want to make sure I know what to do.
Does the End Link go in this whole? Also, is there any specs on the torq for the end link bolts....or is it the old "good in tight" rule with maybe a drop of blue locktite?
The reinforced hole on the bottom of the arm. It really is a ver simple straigt forward install and literally impossible to mess up. The bush squish for the drop links is best set with the weight of the car on the wheels.
Originally Posted by Synner View Post
No the outer portion of the arm on the bottom.
Old 10-10-2012, 07:51 PM   #100
JusticePete
Check The Book. Sway Bar Chapter.
Pedders 2010 Chevrolet Camaro Suspension Evaluation
Foundational 5th Gen Required Upgrades
Lowering Coils and Coilovers
Trouble Free, OEM Quiet V6 Lowering
Sway Bars
Suspension Bushes
ZL1 / CTS-V Brake Upgrade for the SS
Wheels and Tires
Bush Timing, Alignment and Torque Specs
Pedders USA Camaro 2.0
Lingenfelter L/28 Tech
5th Gen Wheel Hop and Drag Race Setup
Thermal Management
Running Changes Made to the 5th Gen by Chevrolet
Public Track Test #1
Public Track Test #2 Camaro vs. Mustang Supercar Shootout
Caution: Test driving any Pedderised vehicle can be dangerous. Pedderised vehicles have been known to induce suspension envy and sleepless nights filled with longing. Before test-driving any Pedderised vehicle, check with your banking and accounting professionals. Pedderised vehicles are known to induce credit card bills and reduced bank balances. There is no antidote.
We have a large gallery on both the FE3 upgrade and the ZL1 on Facebook.
And don't forget to VOTE!
Old 10-10-2012, 07:51 PM   #101
caverman
caverman's Avatar
Drives: '69 SS Convertible
Ok....thanks.
So, I'll put them on pretty much hand tight. I'll then get the wheels back on, probably put a stand under the tire, lower it down to get the weight on it, and then tighten them good and tight.
Look forward to the install. Just looking at the FE3 vs FE4 setup it looks to be a no brainer upgrade.
Build Journal
Old 10-10-2012, 07:53 PM   #102
JusticePete
Ok....thanks.
Both wheels need load. If you have 10mm of thread out of the nut in the air, you'll be almost dead nuts on.
Old 10-13-2012, 11:19 AM   #103
ayceman
Drives: 2007 Dodge Charger SXT, 2010 2SS
If I wanted to install the rear monotube dampers from the 1LE would it require me to use the FE4 Rear Lower Control Arms? Or could I get by using the FE3 ones?
ayceman is offline   Reply With Quote
Old 10-13-2012, 11:20 AM   #104
JusticePete
The arms are good to go, but what would you use for front struts?
Old 10-13-2012, 11:21 AM   #105
ayceman
I would assume I would install the front 1LE struts as well, it seems like it would be not that difficult.
Old 10-13-2012, 11:30 AM   #106
JusticePete
That will work.
Old 10-13-2012, 11:48 AM   #107
ayceman
That will work.
Thanks for the info
Old 11-09-2012, 10:05 AM   #108
twmotox
twmotox's Avatar
Drives: 2013 Camaro 1LT RS
For an economy upgrade to a 2012 1LT would the 1LE or ZL1 sways make a decent upgrade? I keep reading that the 1LE suspension parts are not that substantial of an upgrade but if that is the case then what in the world makes the 1LE handle so well? Just trying to weigh out all of my options and not spend anymore than i have to. I hate to be a penny pincher but I am self employed and this economy is killing me.
Loyalty above all else except honor!
twmotox is offline   Reply With Quote
Old 11-09-2012, 10:47 AM   #109
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Our ZL1 front and rear sway bars were a huge upgrade over our stock v6 bars but we autocross so the diffrence was easy to see from one sunday to the other and for 300 for the bars that hard to beat with aftermarket
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 11-09-2012, 08:30 PM   #110
twmotox
twmotox's Avatar
Thats what i thought. The OE prices for the ZL1 bars is very reasonable and has to be a substantial upgrade over stock
Old 11-24-2012, 11:08 AM   #111
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
So I got my 1LE suspension and pedders goodies installed. I can say compared to FE3 its night and day. Its very firm but not harsh, I like it. I don't have my stage III radius rod inserts or rear cradle bushings installed yet, that had to be saved for another day. I expect the car to be very tight once those are installed.
Oh side note, Petes right. Both front and rear are monotubes.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 12-09-2012, 07:55 PM   #112
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Does anyone know if the 1LE Subframe Bushings and the ZL1 Subframe Bushings are the same or different? If different, which are better?
blazzin1 is offline   Reply With Quote
