Old 07-26-2012, 11:43 AM   #1
NDC123
The Machinist
Drives: 2012 2SS/RS LS3 IBM silver rally
Exclamation Idle surge after pulling out of gear?
When I pull ut of a gear sometimes I get an idle surge of about 500 rpm. instead of it staying down at around 500rpm it will surge up to about 1000 then back to 500 then to about 750 then finally rests back at 500rpm. Any ideas what this could be? I have a tune from Ted at JRE ....could this be a tune problem? Please help.
American Racing Headers w/high-flow cats and x-pipe, Flowmaster American Thunder Axle-back mufflers, VMAX ported throttle body, CAI intake, ADM race scoop, RX Catch Can, PEDDERS Street Z package-ZL1 sways-XA Coilovers, PFADT trailing arms-toe rods, RPM 3:91 gears, RPM Stage V Trans, ADM diff bushings, tune by ADM, and still bustin' knuckles!
NDC123 is offline   Reply With Quote
Old 07-26-2012, 11:58 AM   #2
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Mine does something similar. When I am coasting down and I pop into neutral and let out the clutch - the rpms will blip up to about 1400 and then drop back down to my normal idle of 925 ( high idle because of cam). I've always chalked it up to a small quirk that comes with a cammed tuned car. It does it every time and only in the way I have mentioned it so it doesn't affect drivability or saftey ( I'm in neutral with the clutch out) so I just live with it. Not a biggie for me - just odd. My guess is that it is some time of brief conflict between the MAF and ECU.
note: Mine has been fully dyno and street tuned by Vengeance - and other than this one little oddity - it runs great!
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 07-26-2012, 03:40 PM   #3
NDC123
The Machinist
I talked to a very reliable source and he said it was more than likely a vacuum leak somewhere.
Old 07-27-2012, 01:20 AM   #4
20camaro12
20camaro12's Avatar
Drives: 2012 45th anniv. Convertible SS LS3
The last time I had an idle surge such as this I found a vaccum leak in the intake. I have another one that is killing my MPG, but haven't found the source yet.
20camaro12 is offline   Reply With Quote
Old 07-27-2012, 01:06 PM   #5
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
Wish I knew how to hunt vacuum leaks on a DIY basis. Im assuming I have one too as my true neutral coasting causes my idle to ramp up about 150-200rpm..
The 2010 Sin is offline   Reply With Quote
Old 07-27-2012, 01:30 PM   #6
checkyoself
Drives: 2011 Camaro 2SS/RS
^^ Mine does too, after headers/CAI/Jannetty tune. Wondering if its a normal thing. Definitally a 100-200 rpm back and forth thingamajig happening after clutch is pressed in at stoplights.
checkyoself is offline   Reply With Quote
Old 07-27-2012, 02:02 PM   #7
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Yep.. I find the same behavior with my LS3 and recent JRE 470 Cam with CIA with ported T Body fed by JRE Scoop headers and tune.
I am sure Ted will add his thoughts once he reads this
I am thinking this is new behavior, could be related to the ported t body if anything at least in my case, I surely dont see this as a problem, just new behavior as result of the get gone goodies!!
RogerBzSS is offline   Reply With Quote
Old 07-27-2012, 05:52 PM   #8
Mongoose03
Mongoose03's Avatar
Drives: 2011 2SS/RS Camaro
Frank
2011 2SS/RS L99
GMPP Exhaust
Mongoose03 is offline   Reply With Quote
Old 07-27-2012, 06:01 PM   #9
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
Mine also rev's up i never thought it could b a problem. Don't have anything from Ted. So it is not just his tune.
Old 07-27-2012, 08:40 PM   #10
booenson
Drives: 2010 1SS/RS M6
My car has always done it, bone stock except for a ported throttle body.
booenson is offline   Reply With Quote
Old 07-27-2012, 10:27 PM   #11
20camaro12
20camaro12's Avatar
Common denominator it sounds like is the ported TB. Wondering if it could be the ported TB.
Old 07-27-2012, 11:49 PM   #12
BWood
BWood's Avatar
Drives: 2010 Camaro 2SS/RS M6
No ported TB here but I get the same thing. JRE cam and tune. I'll be lookin' for a vacuum leak tomorrow.
BWood is offline   Reply With Quote
Old 07-28-2012, 05:51 AM   #13
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Mine bone stock didn't do it, addition of ported throttle body is when it began.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 07-28-2012, 06:48 AM   #14
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
Every car does it. With a stock engine and mufflers I bet it goes unnoticed.
Pollock is offline   Reply With Quote
