Old 02-26-2015, 07:01 PM   #1
CyberGreyConvertible
Dunder Mifflin Inc.
CyberGreyConvertible's Avatar
Drives: 2012 2SS/RS Convertible
HELP - Oracle Mailslot Scanner Install Problem
I'm installing the Oracle Mailslot scanner, and I'm having problems. The scanner is powered on CONSTANTLY. Once I connect the power to the fuse box bolt/lead, the scanner immediately comes on and the remote is not shutting it off. The battery is brand new in the remote, but the scanner will not turn off. It just keeps glowing.
While installing it, the car is off, I don't know if that affects it. The scanner just will not turn off or respond to the remote. I need help!!
Black wire is going to ground (screwed into the body of the car)
Red is going under the bolt that's attached to the fuse box.
I followed Oracle's video, but the scanner is just constantly on.
Help, please! I appreciate all input!
** I know this may not be the correct thread, but I'm kind of freaking out right now :( **
CyberGreyConvertible is offline   Reply With Quote
Old 02-26-2015, 07:18 PM   #2
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
I've had problems with the remote. It might be that. Sometimes it would work but sometimes it doesn't. Mine was installed at the fest. Give them a call. If you know someone with a scanner ask them for the controller just to see if that's it
camarosspower is offline   Reply With Quote
Old 02-26-2015, 07:22 PM   #3
Dunder Mifflin Inc.
Will other controllers work with it? The scanner just glows and doesn't change patterns at all.
Old 02-26-2015, 07:39 PM   #4
Chevy9534
Chevy9534's Avatar
Drives: 2018 ZL1 A10
My remote has to be directly in front and no further than a foot away. See if that helps
Work in progress
Chevy9534 is offline   Reply With Quote
Old 02-26-2015, 07:45 PM   #5
Dunder Mifflin Inc.
Do you remember if your scanner turned on immediately after you wired up power/ground?
Old 02-26-2015, 07:52 PM   #6
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
My remote quit working after a week or two, I last left it on the solid pattern and tapped it into my halo wire so it comes on and turns off with the halos/headlights only. This way I don't need the remote
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 02-26-2015, 07:55 PM   #7
Dunder Mifflin Inc.
I'd rather put out a campfire with my face than have to send this whole thing back. I'm so frustrated right now, you guys have no idea
Old 02-26-2015, 08:29 PM   #8
Dunder Mifflin Inc.
I luckily have an extra LED controller / remote laying around (actually found it in the center console when I bought the car). I'm hoping that might work with the scanner.
Old 02-26-2015, 09:03 PM   #9
camarosspower
The remote will work on all scanners. When mine doesn't work ill borrow my Buddy's and viseversa. When they first hooked it up it was on auto pattern so that's normal
Old 02-26-2015, 09:06 PM   #10
Dunder Mifflin Inc.
So, when they wired it up it immediately powered on? I'm just wondering if that's normal.
Old 02-26-2015, 09:07 PM   #11
Dunder Mifflin Inc.
This is the extra remote I have. The only difference with this and the one I got with my scanner is the color of the remote. So, if god's really on my side, this remote will work with the scanner. I really really really really really really really really really really really really really really really really really really really really want this remote to work with my current scanner so that I don't have to have it fixed/replaced.
Old 02-26-2015, 10:02 PM   #12
camarosspower
Yes completely normal. That's the same remote that I have
Old 02-27-2015, 09:23 AM   #13
Dunder Mifflin Inc.
Going to wire up the scanner again soon and try both remotes again, hopefully one of them will actually control the scanner.
Old 02-27-2015, 09:25 AM   #14
Dunder Mifflin Inc.
Going to wire up the scanner again soon and try both remotes that I have. Hopefully one of them will work with the scanner.
