#Camaro6
Go Back   CAMARO6 > CAMARO6.com General Forums > 6th gen Camaro vs...
Old 06-15-2015, 04:53 AM   #1
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
6th gen V6 A8 as fast as 4th gen LS1?
Sounds a bit far fetched at first but when you start looking at the two on paper it starts looking closer to reality than fantasy. Well, that is if AL O's promise of a 300lb weight reduction holds true on the V6 model. The LS1 kills the V6 on torque but the superior gearing/shift time/shift recovery could balance that equation (maybe). Let's take a look at the known specs and compare.
1998-2000 base Formula/Z28-
Curb weight-3425lbs
Power-335HP/350TQ
4L60E gear ratios with the 3.23 rear gear multiplied-
1st-9.88
2nd-5.24
3rd-3.55
T56 gear ratios with the 3.42 rear gear multiplied
1st-9.09
2nd-6.08
3rd-4.44
4th-3.42
2016 Camaro V6-
Curb weight-3407lbs(projected base)
Power- 335HP /284TQ
8L45 gear ratios with a 2.57 rear gear ratio multiplication (the 2.57 ratio is to account for the different tire height)
1st-11.87
2nd-7.81
3rd-5.31
4th-4.26
Will the superior gearing, shift times and shift recovery be good enough to overcome a 66lbs of TQ disadvantage? We will have to find out. I don't think it will but I do think it will end up being damn close. Like only a couple tenths and mph.
To give you an idea of how fast the new V6 could potentially be the hero ET runs for a 4th gen LS1 F body are in the high 12's with hero traps in the 108mph range. Most everyone into cars has read about or heard of the Evan Smith piloted bone stock 1999 Z28 that ran 12.8 and the 2001 SS that ran a 12.9 (the SS's run was in positive DA summer heat BTW) but there are many other LS1 f body cars that ran high 12's as well by private owners. Even 1 or 2 A4 cars did it although the M6 cars were faster with the right driver.
If the weight holds true I think V6 hero times could be in the low 13's and that is pretty damn quick for a lower model Camaro. If I get a 6th gen it will be a SS or bust but this is meant to excite those of you who are looking at getting a V6.
Old 06-15-2015, 07:49 AM   #2
Cody6.2
Drives: 2012 Camaro 2SS
It's pretty common knowledge that the BHP of the LS1 was 350 across the board. So using 335hp for comparison sake is already skewing the figures. On top of that GM can dream all they want but no 2016 is going to hit a curb weight of 3400lbs.
Cody6.2 is offline   Reply With Quote
Old 06-15-2015, 09:18 AM   #3
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
You are correct about the HP for the LS1. I think it should also be noted that a majority of LS1 A4s had 2.73 gears. The 3.23 was an option found most often on the SS/WS6 cars.
You prepared to eat those words about curb weight? Pretty sure he said the base 4 and 6s will be as much as 300lbs lighter than the comparable 5th gen models, with extra the technologies.
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3
"Voices in your head are not considered insider information."
3800 Status - 6/16/16 (Built!)
6000 status - 6/29/16 (Delivered!)
SuperSound is offline   Reply With Quote
Old 06-15-2015, 09:22 AM   #4
IOMike
Drives: 2022 F150, 87 Monte Carlo
No, it wasn't until the later years that they got the LS6 intake manifold and started putting out more power.
More like 330 then 345hp.
I highly doubt we will see 12.99 from a v6 6th gen hero run. 13.3 is my guess, for a hero run.
IOMike is offline   Reply With Quote
Old 06-15-2015, 11:32 AM   #5
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
I've been saying it should run with most stock ls1 cars and even stock v8 5th gens and each time people either laugh or say Im "reaching". On paper it should be good but we won't ruly know till it puts down some real times. Really exciting to see the possibility of v6 cars running that strong. Good times indeed.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 06-15-2015, 11:37 AM   #6
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
What is weird is that the 1/4th times for the ATS have been all over the place. They seem to consistently get mid 5 second 0-60 times, but I've seen everything from 13.8 to 14.3 for the quarter. Given the A8 adds a new variable to the comparison, I'm not sure what to expect. I hope you are right, but I guess we will have to wait to see.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 06-15-2015, 11:52 AM   #7
SuperSound
SuperSound's Avatar
I think a stock L99 might have it's hands full. Regardless we are looking at a strong V6 that will make 5.7 Chargers/Challengers drivers sweat.
Old 06-15-2015, 01:34 PM   #8
shaffe
Drives: 21 Bronco
Wasnt the LS1 in the 99 Z/28 "rated" at 315HP and the SS "rated" at 325HP?
Just like the Trans Am was 315 and the WS-6 was 325?
shaffe is offline   Reply With Quote
Old 06-15-2015, 01:34 PM   #9
NASTY99Z28
As potent as the ls3 cars are they are also harder to launch so auto vs manual could make for a run with an iffy launch on the SS. I'm just glad the 6th gen gets the full power with an auto this time around. I always felt gm screwed up on that aspect with the 5th gen.
Old 06-15-2015, 02:36 PM   #10
SuperSound
SuperSound's Avatar
'98-00 - 305HP TA/Z28 and 320HP WS6/SS
'01-02 - 310HP and 325HP
Old 06-15-2015, 04:23 PM   #11
mr02Z/28
Drives: 2002 Z/28,1968 Chevelle convert.
I'd be willing to run against anyone who buys a 6th Gen V-6 ...... I have a 4th Gen Z with LS1 4-speed Auto ....... I haven't ran my car recently at the track but when I did I was able to run consistent low 13s ( 13.12@106 was best time and did a 13.2x on numerous occasions) .......... I'm near ATCO but I live in Phila .... PM if anyone wants to test the ruggedness of the 6th Gen V-6 .......
mr02Z/28 is offline   Reply With Quote
Old 06-15-2015, 04:35 PM   #12
mr02Z/28
I will tell you, the 4th Gen cars are very light and I doubt the 6th Gen V-6 will be anywhere near the 3,400lb mark, my guess is the V-6 will be somewhere in the ballpark of around 3,605lbs ..... I had my 2002 Z28 weighed and it comes in @3,370lbs ...... granted mine has Zero options like Zero power everything .... that was the way it was ordered when new
Old 06-15-2015, 04:48 PM   #13
SuperSound
SuperSound's Avatar
Did you miss the part about Al O. saying the 2.0T and V6 were almost 300lbs lighter than the previous gen?
Old 06-15-2015, 05:00 PM   #14
Memphis43
Memphis43's Avatar
Drives: Chevy
I think he did lol
Memphis43 is offline   Reply With Quote
