06-28-2015, 09:47 AM | #1 |
Drives: 2010 Camaro SS Join Date: Mar 2015
LSA/ADM results
LSA kit with 2.75 sc pulley, #65, zl1 pump/adm fpcm, ls3 conversion, headers and 3" exhaust. Dyno results: 499 hp with 8lbs boost. I went with all the recommended upgrades except the heads. My goal was 550 hp! :(
06-28-2015, 09:53 AM | #2 |
My LSA blower got me 650 Rwhp on a auto. But we cranked it up to 14lbs.
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80 “1360 Rwhp 1225 Rwtq 25 lbs of boost” |
06-28-2015, 11:21 AM | #3 |
I forgot to mention the BTR stag 1 cam! Curious, with all these upgrades, does it appear to be low? Thanks
06-28-2015, 11:42 AM | #4 |
My pulley combo was a 2.50 and a 8.66, which resulted in spinning the blower at just under 23k rpm. This in turn made 14 lbs on my set up. I've heard 1 lbs of boost is about 20 hp. You are 6 lbs less then I was, so (6x20 = 120). This would put you in the ball park if you cranked up your boost, so I would say it's your pulley choices.
I am no expert on the subject, but it seems a good starting point.
06-28-2015, 11:53 AM | #5 |
Tune good? Took decent timing? No leaks? Intercooler pump working and all air out of system? Correct and good plugs? Belt on properly so no slip?
If everything mechanically seems good, and tune seems good, time to pulley down.
Nick
Corvette Z06 -1200ish rwhp |
06-28-2015, 11:54 AM | #6 |
'It's an experiment'
What were your starting rwhp and torque? How many miles on the engine? Is yours and LS3 or L99?
-Don
747 RWHP 794 RWTQ
06-28-2015, 11:59 AM | #7 |
LS3 conversion would indicate an auto.
Nick
06-28-2015, 12:19 PM | #8 |
Didn't see that. BTR also makes vvt stage one.
Thanks! -Don
747 RWHP 794 RWTQ
06-28-2015, 02:08 PM | #9 |
If everything checks out ok i would say its in the tune.
06-28-2015, 02:31 PM | #10 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
For sure! Should have made much more power
06-28-2015, 03:53 PM | #11 |
Drives: Anything I want Join Date: Oct 2008
06-28-2015, 04:12 PM | #12 |
Thank you all! I'll answer all questions here!
I have the BTR PDS Stage 1 cam (recommended). K&N cai Inter cooler system circulating and full Tom Wong (tuner), Vanc WA said timing was good Iridium TR7IX gapped 38-40 Belt tension is slightly above top indicator mark, will replace with smaller belt. 550 original miles on car/engine See Dyno attachment Thank you |
06-28-2015, 04:18 PM | #13 |
Mustang dyno is part of it. If you want big numbers go throw it on a dyno jet. Could easily be 530-550rwhp on a dynojet.
Nick
06-28-2015, 04:23 PM | #14 | |
Those were the final numbers after the VVT was tuned. And yes Sunday is family time! -Don
747 RWHP 794 RWTQ
