Old 06-26-2012, 10:27 PM   #1
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
What Does the Max A/C Setting Do? And Other HVAC Q's
Just a click counter-clockwise from "full cold" on the climate control thermostat is the "Max A/C" setting. The owner's manual isn't really clear (pages 8-1 and 8-2) whether it is activating recirculation, which would make it redundant to the actual "Recirc" button. What does it do?
Page 8-2 also states that the recirculation setting may be automatically selected in warm weather and the light indicating "Recirc" will not illuminate. Big Brother much?
Last point: My car's a/c/ has to be manually turned on after the car has been sitting overnight, every time. It makes no difference whether the a/c compressor was running when I turned it off last, even if I left the interior fan on, etc. During the day (I drive for work in this car), it reverts to the last setting I had it on, and the a/c compressor will come online even if I shut the interior fan all the way off before shut-down, which I almost always do, no re-activating the a/c necessary. What's up with that?
And yes, I realize that this is probably in the wrong section. Please move it, Mods, if necessary. And, yeah, I could have searched a little better, and I realize it's probably been covered before...Sorry.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 06-27-2012, 06:14 AM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '20 Corvette Stingray
Johnny, if you have to turn it on everytime, and you left it on when you parked, take it to the dealer, as you have an issue.
to answer you first question....YES, MAX A/C turns on the fan and the recirc to max. The reason its not redundant is a lot of people don't run with the A/C in recirc mode.....so by going to MAX A/c, it turns BOTH on, no need to hit another button.
Old 06-27-2012, 12:09 PM   #3
Chevrolet Customer Svc
Drives: GM Vehicles
John B.
At the end of page 8-1 and 8-2, it states:
Turn to increase or decrease the temperature inside the vehicle. Maximum cooling occurs when the temperature knob is turned to MAX and the air conditioning system is turned on and air is recirculated
inside the vehicle.
Therefore, it is safe to say that the recirculation control should be on and running. If this is not coming on, it may be best to take it to your dealership for diagnosis or troubleshooting.
Brandon
Chevrolet Customer Service
Old 06-27-2012, 12:22 PM   #4
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS
Johnny,
If I'm understanding correctly are you saying that the HVAC doesn't remember the last settings if it sits overnight but it does remember if it's just a few hours?
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2016 Camaro 1LT A8 - "Elmo"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 06-27-2012, 12:27 PM   #5
steveo9043
steveo9043's Avatar
Drives: 2012 45th AE 2SS Coupe
Mine does not remember the last setting either. Pisses me off when I remote start it and get it and the A/C isn't even turned on!
2012 45th L99 SS-Cold air inductions CAI-Dynatech LT's-Solo mach XL catback
333hp/341tq (before LT's)
steveo9043 is offline   Reply With Quote
Old 06-27-2012, 12:29 PM   #6
meissen
meissen's Avatar
Have you tried taking yours to the dealer, Steve?
Old 06-27-2012, 12:31 PM   #7
JohnnyBfromPeoria
Brandon, what was not clear about the wording in the manual was whether the instructions were indicating that the system would take over and activate recirculation by selecting MAX on the temp knob. If all it does is engage the a/c compressor and activate recirc, it just seems a little disingenuous, as all it's doing is combining two functions already available through other switches. It's not like it saves the driver a bunch of time or anything.
The wording could be construed differently to mean that the MAX function works better if the driver selects recirc, not that the car's system does it for the driver. Read it again from that perspective and you may see what I mean.
I have another vehicle that has two a/c compressor settings, econ and a/c. Theoretically, it disengages the a/c compressor at different air discharge temperatures so that in it's econ setting, the compressor would run less frequently. No such functionality on the Camaro, I'm seeing.
Even though the car may automagically decide to use recirc, whether or not the selector is set to recirc, I'd rather have the option to set it my way and have it stay. Gone are the days of a cable-controlled door that positively made that happen. For me then, the MAX setting is both worthless and misleading. The car's going to do what it's going to do regardless of what I want.
Unless it actually does something more...? But I doubt it.
John B.
Old 06-27-2012, 12:33 PM   #8
JohnnyBfromPeoria
Originally Posted by meissen View Post
Johnny,
That is correct. Sounds like I'm not the only one.
John B.
Old 06-27-2012, 12:38 PM   #9
steveo9043
steveo9043's Avatar
I have not, I just recently had to start using the A/C this summer and noticed this. I did have a compressor replaced back in Feb when we had a heat wave but haven't used it since. Thought it might have something to do with that.
I plan on taking it in Saturday Morning.
Old 06-27-2012, 12:39 PM   #10
steveo9043
steveo9043's Avatar
oh and the A/C sucks in it! I mean does it cool down the car? yes on max A/C with fan speed of 6 or more. I think it might be low from them replacing the compressor.
Old 06-27-2012, 07:50 PM   #11
Emig5m
100% Sport Møde
Emig5m's Avatar
Drives: '17 Civic SI + '04 SVT Lightning
lol... And I just made a thread a few days ago asking everyone if they where happy with their AC performance. On the plus side, it has the quickest warm up time for hot air on cool mornings out of every vehicle I've owned.
Emig5m is offline   Reply With Quote
Old 06-27-2012, 10:45 PM   #12
GEEKFREEKSCOTTY
Autoboticus Roboticus
GEEKFREEKSCOTTY's Avatar
Drives: 2011 Camaro 2SS/RS
It seems like my AC isn't that cold. It gets cool, but not icy like I would expect.
GEEKFREEKSCOTTY is offline   Reply With Quote
Old 06-28-2012, 05:32 AM   #13
styphon
styphon's Avatar
Drives: 2011 Camaro 2ss
Am I just in luck? My car remembers the ac settings every time. Also the ac works great, most of the time I have it on only one or two clicks.
styphon is offline   Reply With Quote
Old 06-28-2012, 06:26 AM   #14
DeAdMiKe187
Drives: Black 2012 2LT
Occasionally happens to me (especially with Remote Start). The 3 of us with this problem all have 2012 models. Interesting.
Recently, I noticed that the lights for AC/Recirc didn't illuminate until I put the key in and turned it, so I'm not 100% sure if the AC was working properly those other times I remote started the car, because I would press the AC/recirc buttons before putting in my key (which probably turned them off, because they were probably 'on' even though the light wasn't on). I don't know. I'll pay more attention to it next time.
DeAdMiKe187 is offline   Reply With Quote
