04-21-2014, 08:12 PM | #1 |
Drives: 2011 Camaro 2ss Join Date: Mar 2012
Aftermarket header p1133/p1153
I received both of these error codes a year after changing out my exhaust. I had them cleared, but they reoccurred again after 200 miles.
I have kooks LT header, solo HFC cat, and solo exhaust. My o2 sensors are connected by "extenders" as they can't reach without them. I have never had a tune So the problem is - now I can't pass inspection. Took to a shop, they told me to drive it around, which I did and after a few hundred miles it threw the same codes. What do I do? Buy new O2 sensors? Buy a tuner?
04-21-2014, 08:38 PM | #2 |
Drives: 2010 2 SS Join Date: Oct 2013
you'll need to have it tuned!
04-21-2014, 08:57 PM | #3 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
Yup...you need a tune bud.
Ive got the same issue, and so does EVERYONE who has long tubes on these cars without a tune. The reason this happens is because the primary O2 sensors are further down the exhaust stream where its not as hot anymore, hence the switching slow response codes. Ive heard of people welding up a bung in the #7 and #8 primary tube further up closer to the head to avoid tuning. But that aside, you need a tune. This topic has been beat to death since the LS1 first came out and was super popular with people who put long tubes on LS1 fbodys and C5's back in the day. The general consensus/answer = TUNE. Just as an FYI...those P01133 and P01153 dont necessarily trip the CEL on. When I get those DTC's they show up as a pending fault (yellow) and not an immediate fault (red) on my scanner.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
04-22-2014, 12:07 AM | #4 | |
HT5 in the 626
Drives: 2014 Camaro 2SS/RS Join Date: Nov 2013
2014 L99 Camaro 2SS/RS ~ Flowmaster American Thunder Catback ~ Cold Air Inductions CAI ~ VMAX Ported TB ~ ARH Catted LTs ~ Tuned by Ted @ JRE A wise man once said, he who eats crackers in bed get crummy sleep. |
04-22-2014, 04:28 AM | #5 |
I have had longtubes on my car for 3 weeks and haven't gotten a check engine light yet.
04-22-2014, 04:50 AM | #6 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
You will.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
04-22-2014, 05:25 AM | #7 |
Moderator
I got those, too. They'll be gone with my permanent tune.
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
04-22-2014, 07:27 AM | #8 | |
I have also read that sometimes a tune will not stop the P1133 and P1153 errors and they must be disabled in the tuning program? I would go crazy if I went to a tuner pay a couple hundred then fail inspection *again*
04-22-2014, 07:38 AM | #9 |
Moderator
If you clear it, it shouldn't come back right away. You might consider leaving the CEL until right before the inspection and clearing it down the street from the inspection facility.
04-22-2014, 11:52 AM | #10 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
They plug into the OBDII port in AZ, and you will still have readiness codes set but no CEL and fail .
OLD GUY FLYING FAST AND LOW
04-22-2014, 12:16 PM | #11 |
Drives: E92 BMW M3 Join Date: Oct 2012
You have been running headers w/o a tune for a year? EEK
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
04-22-2014, 12:49 PM | #12 | |
So I think I have two ways around this... 1) buy a tuner device, get a map - and then hope it works, if not then "adjust" the p1155 and p1153 codes 2) Pay a tuner w/ dyno (about 50 minutes away) almost the same price to tune the car. He says it "may take a couple tries" - and it "is illegal to adjust the p1155/1553 codes"
04-22-2014, 02:16 PM | #13 | |
10-bolt Destroyer
-Street Racing is illegal -Smoking indoors is illegal -Doing burnouts is illegal -Speeding is illegal What isnt illegal? Where do you stop with the morality of it all? The bottom line is, if you want to keep LT's and pass inspection, you'll need a tune. Just as an FYI, because THAT tuner told you "tuning out 1133 and 1153 is illegal" would ensure i never let that guy EVER tune my car. This is a COMMON issue with having longtubes/modified exhaust/cats/etc. With a proper tune(r), they will FORCE emissions readiness in the tune. HP Tuners, EFI Live, etc all have the ability to do this and tell the ECU to not trip a CEL/Fault for P01133, P01153, P0420 & P0421. Any good tuner should know this. They wouldnt put the feature in the tuning software if it wasnt required when tuning for certain/specific mods, like longtubes.
04-22-2014, 02:30 PM | #14 |
Drives: CTS-V Join Date: Aug 2008
A tune made VERY little my intake/header car(5-10hp) . Ran it for 2 years no tune, if it wasn't for the darn cel I would left it alone .
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
