09-20-2017, 12:08 PM | #1 |
Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
Wilwood Aero 6 vs. GMPP Brembo 6 Brake kit
I'm not one that normally posts "which one of these is the best" kinda posts, but I'm getting pulled off track in purchasing the 6 pot GM/Brembo brake upgrade by the Wilwood Aero 6 kit. I've done my homework a looked at a lot of posts on both of these kits and I'm beginning to think that going with the Wilwood over the GM Brembo kit isn't a bad idea.
The Brembo kit appeals to me in that, well, its GM, therefore OEMish. Known product that works well and falls in line with my sleeper/grand touring build I'm putting together. Pads are easy to find from various sources. The negatives seem to be initial bite is not as strong as the Wilwood kit (reading between the lines here) and seems to be a little heavier. The Wilwood kit seems to offer a two piece, larger diameter rotor (15"), better initial bite, Aluminum calipers for weight savings, a little less expensive, and a good selection of pads. And if you feel you need them, thermo isolated pucks to reduce heat transfer to the brake fluid. With no other information than other opinions, it would seem that the overall braking performance leans toward the Wilwood's. The negatives are, a little harder to change pads, somewhat more open to the environment, and not OEM looking. I seem to be heading towards building a trackable car and 6 piston brakes have always been part of the overall plan. I don't think there is a bad decision here, but input from you folks is always welcomed. Your thoughts? |
09-20-2017, 12:47 PM | #2 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
not sure about all that, however, my GM brake kit is a 2 piece rotor and is fantastic at what it does. Only down side that I've seen is the brake dust. cant stand it.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
09-20-2017, 03:41 PM | #3 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I kept my OEM pads for that use. |
09-21-2017, 10:29 AM | #4 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
willwood stuff is ok. They tend to leak and need to be rebuilt quite often from what I have seen.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
09-21-2017, 05:28 PM | #5 |
09-21-2017, 05:33 PM | #6 | |
I don't think there is any huge difference overall in performance. Isn't the brake dust issue manageable with different pads? |
09-21-2017, 06:19 PM | #7 | ||
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
100,000 miles on the aero6 setup with 2 piece rotors on my 2013 Camaro, no leaks at all. sold em and put the money towards the current Camaro. same driven uses as the charger. however, one here with the 6 piston brembo calipers on a 1le: Quote:
there was also 2 guys that do serious track driving on a CamC group I'm in that stated the same. one thought it may be the pads used and how much thermal conductivity is occurring. personally if wheel choice was critical and youd have/want to use 18... I would go with wilwood. if you plan to use 19 or 20, it would be a coin flip for me on wilwood vs OEM, but the brembo setup, you may find that there is a larger pad choice over brands.... as far as the 4 vs 6.... theres a guy in the road and track forum running the 4 pistons in a class. trying to find that post now, but its his own race site... considering what they've done race wise with the car, the 6 piston can be a want option, more so than a need. all personal choice and what you plan to do with the car overall I guess.
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant Last edited by PolynesianPowerhouse; 09-21-2017 at 06:59 PM. |
09-22-2017, 09:49 AM | #8 | |
It was another interesting comment on the bleeders posted by the 1LE track guy. I've had the same problem on my sport bikes and found that a tiny strip of Teflon tape took care of the loosening. |
09-22-2017, 10:41 AM | #9 |
Drives: 71 Camaro '18 1LE Join Date: Feb 2016
The Aero 6 is easily the bet caliper in the Wilwood lineup but I don't think it is better than the OE Brembo. The W6 is the worst caliper they ever made (notice you can't buy them anymore) they were all replaced with the Aero. I have never had leaking issues with any Wilwood calipers and over the rears have installed hundreds of them on mostly off topic cars.
Initial bite is a characteristic of pad compound. Between the two I would run the Brembo. Given a choice, StopTech.
Donny
09-22-2017, 04:17 PM | #10 |
Drives: 2017 2ss, m6 Join Date: Jan 2017
I have the Wilwood 6 piston kit that you are looking at. I chose the wilwood kit over the brembo kit for several reasons. First, a lot of race shops in my area stock pads, hardware, and other parts that you will need if you put the car on the track often. Second, while I dont have 10 different brands of pads to choose from, I have more than enough compounds to choose from and Wilwood does publish all needed data for me to use. Lastly, I will always prefer and use radial mount caliper whenever possible. Brembo makes excellent stuff, no doubt about it, but the GM offering is really setup for a production street car and isn't as focused as their much more expensive kits are. You cant go wrong with either...just get ready to part with the money!
09-22-2017, 09:02 PM | #11 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2006
AP Racing brakes for the win
09-24-2017, 03:34 PM | #12 | ||
as of now, I know brembo GT and wilwood have a kit that fits 18's if I need something in the 6 piston range. but as someone pointed out, pad feel, modulation, temp fade, and coefficient of friction is all up to the pad choice. I did find the article with some help from another in the road and track forums... http://www.camaro6.com/forums/showth...ighlight=build the article is here: https://theblock.com/news/wheel-whee...-tells-you-how Quote:
I can say that with the wildwood's I ran the BP-20's most of the time, but used the Polymatrix E pads for track use. towards the end before I removed em to start parting out the car, I just ran the polys daily driven. lots of loud noises coming to stops, but you could stop on a dime and give someone 9 cents back. so even if you go Wilwood, like Deakins said, there a good amount of variety out there to get the job done. I always err on the side of whatever you can get parts and pads for in an emergency. oem vs Wilwood, would be a toss up still. now if it were brembo aftermarket GT setups, or Stoptech, then you're talking a slightly upscale league.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
09-25-2017, 12:21 PM | #13 |
PolynesianPowerhouse: Your input is always helpful in this area, but there is one point that I struggle with; that is the comment from the SCCA builder that states that "...the 6 piston package but it carried a 100# weight penalty." I find it hard to believe that there is a 100# weight differential between the 6 piston and the 4 piston. Perhaps 10#, but not 100#. I wonder what he was really meaning there. Is it a dead weight add-on requirement?
All of the comments so far are giving me much better insight and will help in making a purchase decision. I'm one of those that believes that brake upgrades are mandatory when you do a big power increase. With the E-Force supercharger installed, a brake upgrade just seems to be the right thing to do. Last edited by Atomic Ed; 09-25-2017 at 02:10 PM. |
09-25-2017, 12:25 PM | #14 |
