02-22-2018, 07:44 PM | #1 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Hard water spots on windshield
I just bought a used ‘16 SS and I noticed that the windows have a lot of hard water spots that won’t come out. I saw videos about using Bar Keepers Friend cleaner and polish to get water spots out. Is that good stuff? Any recommendations?
02-22-2018, 07:44 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Clay bar maybe?
02-22-2018, 08:01 PM | #3 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
For the quickest easiest solution, use a glass polishing disk and glass polish. If you don't have a dual action polisher, you can get an adapter to use a power drill.
https://www.autopia-carcare.com/glas...l#.Wo91syXwbIU https://www.autopia-carcare.com/wolf...l#.Wo91yyXwbIU You can also try a razor blade and some distilled water/vinegar mix.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
02-22-2018, 08:04 PM | #4 |
Drill adapter
https://www.detailedimage.com/Lake-C...080/Rotary-S1/ Backing plate for glass polishing disk https://www.detailedimage.com/Lake-C...P227/73-mm-S4/
02-22-2018, 09:20 PM | #5 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Soak paper towels in vinegar and lay them on your windshield for a few hours, that should soften the spots for removal with a claybar.
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
02-22-2018, 09:28 PM | #6 |
You can remove the spots chemically (vinegar, CarPro water spot remover) or mechanically with an abrasive polish and a pad or glass polishing disk. Don't use steel wool (some say you can, Mike Phillips says steel scratches glass.) Claybar is probably not going to be much help. Neither Mike Phillips nor McKees37 recommends clay on glass water spots. Polishing is by far the fastest way.
02-22-2018, 11:29 PM | #7 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Carpro's Water Spot remover works well.
2SS Camaro, Garnet Red, Adrenaline Red, NPP, MRC, A8, 5 Split Spoke Bright Silver Wheels (56W)
1100 Status - 7/24/15 (Ordered) 3800 Status - 10/13/15 (Built) 6000 Status - 12/22/15 (Delivered) |
02-23-2018, 11:17 AM | #8 |
Drives: None Join Date: May 2017
Clay bar should work fine...
2017 HBM SS 1LE | EE Catch Can | Gm Clear tails | Rotofab CAI | DD Smoked sidemarkers | StainlessWorks Catback
02-23-2018, 11:57 AM | #9 |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
CarPro Ceri glass, that will not only get rid of your water spots but also polishes it.
02-23-2018, 08:31 PM | #10 |
Drives: The shiny ones. Join Date: Mar 2010
I always had good success machine polishing with MF pad and our Correcting Polish.
02-24-2018, 03:47 AM | #11 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
I'd recommend using CLR in increasing dilutions starting at 1 part CLR 10 parts distilled water.
CLR ... strong stuff. |
02-24-2018, 10:59 AM | #12 |
A must have for soaking foam gun screens!
02-24-2018, 02:02 PM | #13 |
BL1ZZRD
I used the Bar Keepers Friend powdered cleanser and polish. I watched the video online and mixed the portion of water and 1 teaspoon of cleanser. This had no effect. I figured it needed to be a more aggressive mix so I took the wet microfiber towel I was using and just lightly added powder to it until I got the right results. Worked great! Did my windshield in about a half hour. Now to do the rest of the windows tomorrow. Thanks for all of your suggestions!
02-24-2018, 02:24 PM | #14 |
Drives: 2018 1LT Camaro Join Date: Aug 2017
