01-01-2017, 02:53 PM | #1 |
Drives: 2010 RS/SS Join Date: Dec 2016
Long term storage
I store my car for 6 months of the year in a dry heated shop.I was wondering how often other people start their cars while stored.My car is a supercharged l99
01-01-2017, 03:27 PM | #2 |
This is always a good question but from last I knew I'm understanding that on today's cars they don't need to be started and can go a long time in storage. I guess they say if you are not going to drive it and get it up to temp then your doing more harm than good due to moisture being created by only starting once in awhile and not getting up to temp moisture is trapped internally. I put our cars up for about 5-6 months a year and I just top off the fuel , add fuel additive and park on carpet squares under each tire. The carpet helps dry rot if you park on concrete floor over long period of time.
Car mods: never enough!
01-01-2017, 03:41 PM | #3 | |
I know you said it's in a dry heated garage but there is still moisture in the air. I store a motorcycle for 6 months of the year . It sits on a battery tender with Stabil in the tank. Believe me it sucks I love listening to the sound of my Gixxer . What the guy above me said .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
01-01-2017, 08:11 PM | #4 |
I store mine for 6 months too. I learned that it is imperative to take it out on monthly spins. I had a Mustang that I stored for 6 months & the A/C system failed after 35,000 miles. The dealer said the A/C has to be run a couple of times during non a/c months. 6 months can also ruin a battery. You can disconnect the cables, but then time & stations have to be reset. btw, the a/c repair was north of 700.00.
01-01-2017, 08:15 PM | #5 |
I had a 08 Mustang I stored for 6 months, found out that was a strain on a/c system. Dealer said on off months the a/c system needs to be run to keep the system from breaking down. That was pricey, north of 700.00. I learned to take my stored Camaro out monthly for a spin; to get condensation out, save tires from sitting too long & keeping battery in tip top shape.
01-02-2017, 11:02 AM | #6 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
It will be fine. Get a Tender or some other controlled trickle charger, tires off the ground, as mentioned, on carpet and inflated to recommended max to prevent flat spotting, and get a good cover for the car. The advice above about not starting it is sound. Unless you get the oil temps up over 212 degrees for a good period of time, you won't boil off the condensation that starting it in the first place created. Oh also, add some Sta-Bil to the tank, and run the car enough to get it into the whole fuel system.....
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
01-02-2017, 12:02 PM | #7 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
If you can do it, jack stands were recommended to me to save the tires when she sits. I always wondered if it helped or harmed the suspension though.....
01-02-2017, 12:21 PM | #8 | |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
Pretty much what I do except battery tender, tarps to cover the concrete and plywood under each tire. But to be honest tire rot is a non-issue for me as I need new rears every 10-12000 miles so far... |
01-02-2017, 02:09 PM | #9 |
Drives: 2013 SS Convertible, ThumperII Join Date: Nov 2016
I have been storing our Sebring convertible for 10 plus years and this is the first year storing the Camaro (we just got it in July). I agree with the trickle charger or charging the battery once a month or so. I probably brought an extra battery over the years by not doing this at first. We do not run the cars during storage as I think it can create moisture in the engine. I do put plastic under the cars and tuck it up in the trunk, the hood and door sills to keep moisture and critters out. Each car has nice cover for it also. We cold store the cars in WI and this has worked well for us.
01-02-2017, 02:19 PM | #10 |
Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
You are supposed to load the suspension. You set the suspension down on the jack stands so the weight of the car is still on its springs.
01-02-2017, 02:59 PM | #11 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
In my experience, which is ten+ years of storing a car for the winter in an unheated space (where it snows), I always brought the engine up to operating temp, once every couple of weeks when I couldn't do it each week.
Respectfully I never had water in the oil when I drained and changed each spring and I would have the engine out often each year, to clean and detail it and the engine compartment, and re-treat my headers. Every third or fourth year that would mean taking the intake off too, and a couple times, the heads just to check, as gaskets are cheap. I did not note any corrosion damage. I would also move the car ten feet or so, leave it with the wheels turned in a new direction, little things like that. I'd run it through the gears with my foot on the brake, engage and disengage the e-brake, and check under the car for leaks. That's my experience. As always YMMV.
Thread Tools | |
