03-03-2013, 10:51 PM | #1 |
Drives: Black 2SS/RS M6 Join Date: Mar 2010
ZL1 diff cooler
Anyone have pictures or part diagrams of where the cooler lines connect to/up front? Do they connect to the radiator or trans cooler?
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME MGW Short Throw Shifter Complete ZL1 Rearend Swap |
03-04-2013, 06:24 AM | #2 |
Drives: '17 GT350 Join Date: Mar 2012
ZL1's "14 bolt" diff. has an intergrated cooler that sits at the bottom in its own little sump. Transmission fluid is pumped all the way back to the rear into the imbeded cooler, then back out again, sent all the way back to the transmission, which then pumps it forward to the transmission's fluid cooler, then back to the transmission and the cycle starts again.
03-04-2013, 09:36 AM | #3 |
Thanks for the info. I have a ZL1 diff that should be here by mid week, I'm just trying to see if it would be easier to make my own pump and cooler assembly rather then go stock with it. I'm looking for parts diagram of the connection point up front.
2010 LS3 2SS/RS M6
03-04-2013, 09:55 AM | #4 |
Drives: 2011 2ss Join Date: Oct 2012
Tried to attach chevy's pdf
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
03-04-2013, 10:48 AM | #5 |
Thanks Jason. How's the diff going?
2010 LS3 2SS/RS M6
03-04-2013, 11:09 AM | #6 |
Its in the plumbing should be done this week.
03-04-2013, 11:14 AM | #7 | |
http://dougrippie.com/products/drm-c5-diff-cooler-kit/ |
03-04-2013, 11:16 AM | #8 |
That heat exchanger looks almost identical to the one I purchased from GM
03-04-2013, 11:24 AM | #9 | |
2010 LS3 2SS/RS M6
03-04-2013, 01:45 PM | #10 |
The transmission pumps trans fluid to the rearend and then to the heat exchanger to the front of the car. The trans. fluid and diff. fluid do not mix. The diff has a seperate res. wher e the trans fluid circulates.
03-04-2013, 02:52 PM | #11 |
Jason do you have a list of all the part numbers for the lines and the transmission cooler?
2010 LS3 2SS/RS M6
03-04-2013, 02:56 PM | #12 |
E mail me at jpeninger74@gmail.com and I will forward you my delivery reciept. I can't get it to post on here.
03-04-2013, 03:11 PM | #13 | |
Drives: cars Join Date: May 2011
03-04-2013, 03:42 PM | #14 | |
http://www.cadillacforums.com/forums...al-cooler.html This would be great but I don't need it to plumb into the diff fluid, just need to make it like a intercooler but would think that you would need a reservoir unless this could work as a classed loop system with the diff.
2010 LS3 2SS/RS M6
