Old 06-03-2019, 08:27 PM   #155
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Nice!!! I wanted to get it about a month ago but they won’t ship to CA
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 06-03-2019, 08:30 PM   #156
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Sounds like you need a buddy in an adjacent state, then have it sent there so you can go pick it up and bring it back
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 06-03-2019, 08:36 PM   #157
760bowtie
760bowtie's Avatar
Yea that’ll probably be my next move. I can literally pick it up from their warehouse but they won’t sell it to me LOL
Old 06-03-2019, 08:52 PM   #158
Moreair1
Moreair1's Avatar
That's sucks, wonder if they would sell it to someone with a out of state liscence while they were there
Old 06-09-2019, 08:15 PM   #159
Moreair1
Moreair1's Avatar
Picture of what's included
Old 06-13-2019, 07:54 AM   #160
Moreair1
Moreair1's Avatar
https://youtu.be/eKtZ45jlx78
Old 06-13-2019, 07:55 AM   #161
Moreair1
Moreair1's Avatar
Most of the kit went well, items that may be throwing the kit off for a convertible( a coupe I dont believe you would have any issues other than those cheap ass clamps), the agp turbo pipe off the turbos, there is a new piece with the kit but it doesnt have the same clamping system on the turbo(also if you do use it you need to request or install o2 sensor bungs so I used the agp pipe instead, but I had to use a adapter which I believe through off the kit enough to make the stainless works kit work less than idea with clearance issues for the bracing, I actually had to bend the braces some for it to work, but I may end up having to use spacers since it literally has 0 clearance on top or bottom of the exhaust
Old 07-20-2019, 05:46 PM   #162
Moreair1
Moreair1's Avatar
Update on the braille 21 lb battery wont hold charge past 4 days and also believe its dead now, so for a racecar i would recommend, but for a street car i would keep the full size battery
Old 08-13-2019, 06:00 PM   #163
Moreair1
Moreair1's Avatar
3 inch exhaust on dyno
https://youtu.be/BL1VBt2HAFM
Old 04-30-2020, 10:36 PM   #164
Moreair1
Moreair1's Avatar
So just an update to the build, I have added a btr stage 1 tt cam, and now currently in process of adding some pedders coilover plus some qa1 lca's for the rear, after all this ill get an alignment and start working on my new tune
Old 05-08-2020, 05:05 PM   #165
Moreair1
Moreair1's Avatar
New vs old
Old 10-04-2020, 03:30 PM   #166
Moreair1
Moreair1's Avatar
Results from the latest track outing, traction was an issues but I did managed to make this run right after they put down a new coat of stick um, Da 8000 ft and car weights 4600 lbs
Old 10-06-2020, 09:18 PM   #167
Moreair1
Moreair1's Avatar
Next mod some 17s with mt's
