04-09-2010, 06:30 PM | #1 |
Drives: 2LT/RS Join Date: Jul 2009
***EIBACH INSTALL tomorrow***few ?'s
Hey guys! I recently purchased the pro-kit springs and was planning on doing the install tom. just had a few question
-Do you have to cut the bumpstops? it says no in the instructions, but Pfadt springs is a similar drop and does require it....plz clarify -Any advice or tips are welcomed....i've done a few drops on imports i'm assuming this is pretty much the same THANKS A BUNCH! |
04-09-2010, 07:35 PM | #2 |
12.23s@113mph
Drives: 2SS/RS, A6, just a few bolt ons Join Date: Jul 2009
you ought to, if you want the same amount of wheel travel. if you don't cut them, you might bottom out a lot easier.
RIP Cammie 7/15/2009 - 4/1/2011 |
04-09-2010, 07:42 PM | #3 |
Drives: 2011 CGM 2LT/RS black stripes Join Date: Sep 2009
No, you do not have to cut the bump stops. It specifically says so in the paper that comes with the set! I have installed them and had no problems of the shocks bottoming out.
Look at the DIY section there are one or two good write-ups that i used. |
04-10-2010, 12:38 AM | #4 |
+1 dont trim bump stops. didnt do it on mine an have not had a problem. install is easy.
04-10-2010, 12:58 AM | #5 |
install is easy takes about 3 hours, love the handling now its alot better
04-10-2010, 01:56 AM | #6 |
These things are AWESOME. I just got them put in today, tomorrow will post a full write up with pics. You will love them. Are you doing the sway bars too?
04-11-2010, 01:27 AM | #7 |
Hey guys thx for all the input! anywho install went ok except for those damn front sway endlinks arghhh..overall the ride is nice & looks sic...i only have one problem>>> after driving it around a bit its now making a clunkn/knockn sound from the front pass. side..i checkd everything to make sure it was tight...spring was seat pretty well etc..any ideas what it might be? breakn in sounds? should i get an alignment asap? thanks!
04-11-2010, 01:44 AM | #8 | |
04-11-2010, 03:03 AM | #9 |
www.Camaro5store.com
PICTURES/
04-11-2010, 08:01 PM | #10 |
"HILLARY"
X2 I'm planning on doing the same kit. Also what tools did you use to install it yourself? Hoping this is something I can do on a Saturday or Sunday in the garage. Let me know, thanks.
2010 Camaro SS2 L99 Aircharger, Straightpiped, DT long tubes, Dyno tune by Cal Speed
384 HP & 392 Ft/Lbs. 13.203 @ 107.13 mph at Camaro5FestII |
04-11-2010, 08:45 PM | #11 |
YAY! i figured it out...was a loose bolt...anywho it rides great & looks awesome! now just need an alignment..
04-11-2010, 08:48 PM | #12 | |
LINK>http://www.planetlsx.com/tech/How_To...010_Camaro/131 |
04-11-2010, 08:52 PM | #13 | |
"HILLARY"
04-11-2010, 08:59 PM | #14 |
yea i rented one from AUTOZONE $50, they refund it once returned.....overall the springs arent compressed that much at all, i didn't use it when removing most of em, but you will need it when reinstalling fronts..
Thread Tools | |
Similar Threads | ||||
DIY : Install headers on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 70 | 06-25-2020 06:40 PM |
DIY : Install Performance Swaybars in 2010 Camaro | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 17 | 09-14-2015 12:36 AM |
Complete ******** install from a Novice | Susantroy1 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 63 | 07-31-2015 01:25 PM |
DIY : Install catback on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 3 | 08-09-2009 04:36 PM |
