Old 05-11-2014, 04:41 PM   #1
paultheman2007
SWFLGENS
paultheman2007's Avatar
Drives: 2011 Camaro 1SS
Best cam for ls3
Hey I'm looking into putting a cam in my Camaro ss and I really like the night fury I was wondering how much does
It run to get all the materials someone saying 1,000 to 2,000 is that about right even with laybor
SWFLGENS on facebook.
paultheman2007 is offline   Reply With Quote
Old 05-11-2014, 05:07 PM   #2
CryoMan10
CryoMan10's Avatar
Drives: 2010 2SS/RS
Cam choices can be difficult, find a reputable tuner and let him know your goals and then make the decision based on sound judgment. My cam+supporting mods with tune was 2100.
Just realized you have an auto, price will be steeper than ls3 guys.
2010 2ss/RS.
Hurst ST
160T
Vararam Tune only version
comp cam 223/231 112lsa
Stainless headers 1 7/8
Stock H pipe no mufflers
solid subframe bushings
Hotchkiss stage 3 suspension
TSW wheels on NT05
3.91 gears
Nitrous outlet plate system.
CryoMan10 is offline   Reply With Quote
Old 05-11-2014, 09:01 PM   #3
paultheman2007
SWFLGENS
I have a ls3 but thanks
Old 05-12-2014, 06:06 AM   #4
jman17
jman17's Avatar
Drives: 2011 SS-2/1969 SS
Yeah, but still an auto is more expensive than an M6. I spent about $1500 in parts only and did the installation myself. Really pretty easy with some guidance.
1969 SS: SS/DA 427 CI/Auto
2011 SS-2 LS3 M6 MODS: P1X ProCharger, Squash dual fuel pumps, ID fuel injectors, Cam: Pat G designed/EPS Ground (228/234 .629”/.629” 114 LSA +4 advance), Lethal Racing ported throttle-body and intake manifold, Kooks 1 7/8” Long Tube Headers, Dynomax Bullet Cat-Back System, Skip Shift Eliminator
jman17 is offline   Reply With Quote
Old 05-12-2014, 07:31 AM   #5
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Depending on what supporting mods you get with it, you are looking at anywhere from low $2000's to high $2000's all said and done for cam and install.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 05-12-2014, 10:46 AM   #6
djpelosi
djpelosi's Avatar
Drives: 2010 Camaro 2SS/RS
If by "best cam for ls3" you mean which makes the most HP, I've seen countless entries on people swearing my the Night Fury as long as you have all the supporting mods. When I get my cam, it's probably going to be the Night Fury.
2010 Camaro 2SS M6
2" Stainless Power Longtube Headers
3" Full exhaust w/ Off-Road H-Pipe
Bo White Ported Throttle Body
Hurst Short Throw Shifter
Best Time: 12.43 @ 114, 1.99 60' on stock wheels and stock tires
Build Thread
djpelosi is offline   Reply With Quote
Old 05-12-2014, 03:08 PM   #7
RolltideSS
RolltideSS's Avatar
Drives: 2018 SS 1LE
Did you do an ls3 conversion and not upgrade the cam?
RolltideSS is offline   Reply With Quote
Old 05-12-2014, 04:01 PM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Get with Matt@FSP (Florida Speed and Power) to discuss your options. He's just north of you in Bradenton.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
