03-09-2015, 01:33 PM | #1 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
High Compression Woes
So I recently added a set of PRC 255 heads to my car, along with Nitrous. I ordered the heads w/ 65cc chambers making my compression 11.4:1, I have decided to throw on a procharger, even with meth I suppose I will have to go back to my factory heads as the compression ratio is rather high for FI?
03-09-2015, 02:17 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
No, if you have a good tuner it can be done. A high CR will narrow down your tuning window.
03-09-2015, 02:39 PM | #3 |
11.4 isn't that bad. Just like Blake said, tuning window will be smaller, and it will take less timing, but totally doable.
Hell C7s are 11.5 and loving the boost.
Nick
Corvette Z06 -1200ish rwhp |
03-09-2015, 04:39 PM | #4 |
Exactly. I'm stock LS3 compression pushing 12psi
03-09-2015, 06:49 PM | #5 |
Yeah I might just send the stock heads in to be ported and polished, and throw them back on and sell the PRC heads. I just ordered a D1SC stage II tuner kit....
03-10-2015, 02:24 PM | #6 |
Drives: it changes Join Date: Nov 2010
Stick a big cam on it
03-10-2015, 03:39 PM | #7 |
Per Stevies point, static compression is just one thing, dynamic is another. You can have a cam that bleeds off compression, or one that makes it higher than you want.
Nick
03-10-2015, 03:42 PM | #8 |
Drives: 1999 Trans Am Join Date: Jul 2009
Depends on the cam. My personal car runs 11.5-1 on stock pistons. Planning 16lbs on it but I will have meth injection.
03-10-2015, 03:45 PM | #9 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
high compression
I run 11.3 with 21 pounds of boost and 18 degrees of timing on a F1R setup that makes over 1000 RWHP. Running E85 and progressive METH injection
__________________________________________
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
03-10-2015, 04:09 PM | #10 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
You will be fine with a d1 and a good tuner
03-10-2015, 04:12 PM | #11 |
Interestsing comments. I'm biulding another cat and it has a Stealth Ram with 10.8:1 compression and I'd like to add twin turbos and was wondering if my compression was to high.
Todd in Vancouver
'14 ZL1 Camaro '67 Camaro SS Pro-tour in process How hard can it be... Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession |
03-10-2015, 04:38 PM | #12 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
You could get thicker head gaskets but you will be fine with that blower
