#Camaro6
AWE Tuning
Old 05-04-2018, 11:27 AM   #1
45LongColt
45LongColt's Avatar
Drives: 2018 Zl1 Camaro
RotoFab Install
Do you have to disconnect the battery for this install? I did the TM TB install and no need to disconnect it for that, so I figured it would not be necessary for this either, but wanted to check first. Thanks
45LongColt is offline   Reply With Quote
Old 05-04-2018, 12:36 PM   #2
Buzzmanb12
Drives: '17 ZL1
Nope
Buzzmanb12 is offline   Reply With Quote
Old 05-04-2018, 01:12 PM   #3
45LongColt
45LongColt's Avatar
Thanks
Old 05-04-2018, 02:39 PM   #4
Burly
Burly's Avatar
Drives: 2016 Camaro 2SS
But you should. Anytime dealing with electrical components you should disconnect battery, takes 1 minute.
Burly is offline   Reply With Quote
Old 05-04-2018, 02:58 PM   #5
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
The directions say to disconnect. Takes like 30 seconds. I would to reset the computer to more quickly adjust the fuel trims.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 05-04-2018, 03:42 PM   #6
jbp8653
jbp8653's Avatar
Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto
Just FYI........When we unplugged maf it threw a code on start up. Cleared it and all was fine
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv.
1952 C3100 resto-rod. LS6, 4L60e, 228R cam
jbp8653 is offline   Reply With Quote
Old 05-05-2018, 01:38 PM   #7
45LongColt
45LongColt's Avatar
I completed the install this morning. I did not disconnect the battery, nor unplug the MAF, I actually unscrewed the entire MAF housing from the air tube (2 screws) and tucked it away until the new tube was on the car, then just screwed the MAF/housing back on. Entire install took me about 45 min start to finish, including cleaning under the hood. Threw no codes, runs great and definitely smoothed out the rough idle caused by the TM Throttle Body I installed. I didn't notice any difference with just the TB, but coupled with the RotoFab.... you can certainly tell the difference.
Old 05-05-2018, 02:00 PM   #8
Zl1steve
Drives: Zl1
I've been a tech for 30 years it's good practice to disconnect battery whenever you do any sort of wrenching on a car.
Zl1steve is offline   Reply With Quote
Old 05-05-2018, 02:04 PM   #9
45LongColt
45LongColt's Avatar
My only complaint is I wish the hose clamps were black instead of silver.
Old 05-05-2018, 05:07 PM   #10
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Installed my dry filter Roto-fab an hour ago. Didn’t disconnect the battery and test drove it after. Zero codes, lights or problems. To be honest, didn’t notice one bit of difference in sound. (Not testing power yet until 500 miles)
Can'tHave2MuchHP is offline   Reply With Quote
Old 05-05-2018, 07:03 PM   #11
DangerZL1
Drives: 2023 Black ZL1 Auto
You’ll probably have to get into boost to notice the difference in sound.
DangerZL1 is offline   Reply With Quote
Old 05-05-2018, 08:12 PM   #12
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
Also, as others have said the instructions recommend disconnecting the battery. I'm not sure why people don't want to take this quick and simple step. If it said open hood, would you skip that step too? I disconnecting when installing mine.
Inspector 17 is offline   Reply With Quote
Old 05-06-2018, 01:51 AM   #13
CT ZL1
CT ZL1's Avatar
Drives: 2018 ZL1
Originally Posted by Buzzmanb12 View Post
Nope
Past Rides
13 Porsche 911 4S
17 BMW M4
16 Shelby GT 350
07 Saleen Mustang
02 M3 Comp Pack
79 Corvette
CT ZL1 is offline   Reply With Quote
Old 05-27-2018, 08:27 PM   #14
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Going to go rotofab for my Zl1...
What is the difference between oiled and dry?
What would you recommend?
Tx
Biscuit.fr is offline   Reply With Quote
