Old 05-31-2016, 08:09 PM   #1
galvanizedcity
Drives: 1989 Jeep Cherokee
Things to look for when buying a 2013 1LE?
what are some things to look out for when buying a single owner camaro from dealership vs private owner?
galvanizedcity is offline   Reply With Quote
Old 05-31-2016, 09:03 PM   #2
Cammie 2011
Cammie 2011's Avatar
Drives: 2014 Camaro 2ss 1LE and 2013 1LE
I would want a car fax. Maybe take it to a trusted mechanic to look it over, check compression, fluids, etc. Check body panel fitment, paint, weird engine noise. That's what I would look for. Hope this helps.
2013 Camaro 1LE
2014 Camaro 1LE
Cammie 2011 is offline   Reply With Quote
Old 05-31-2016, 09:34 PM   #3
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
^ This plus look at all the jambs, trunk, hood, doors and fuel door. Any visible blowback from a spray gun? If nothing visible, run your fingers down the edges of the jambs. Should be free of any rough lines, indicating tape marks during a repaint process.
"Make yourself sheep and the wolves will eat you"
LT1Zob is online now   Reply With Quote
Old 06-01-2016, 07:54 AM   #4
1leNPP
Drives: 1LE , 1SS , NPP
If you live were they do smog check like in Calif. . Make darn sure you get the stock air box and all the stuff that go with the air box. The Cats and Exhaust manifold . If they have put long tube headers on the car you may need to replaces the hold exhaust . If it was me I look for a car as close to stock as you can get .
1leNPP is offline   Reply With Quote
Old 06-01-2016, 10:39 AM   #5
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
Check the ID tag in the trunk under the carpet to confirm the 1LE option, for this car, go to the middle, next to the bottom line for 1LE. And to the forum!
Old 06-01-2016, 10:59 AM   #6
markgws6
markgws6's Avatar
Drives: 2019 Chevy Equinox Premier AWD
All of the typical used car advice applies, especially Ragnar's. I'd also look inside the wheel wells and maybe inside the wheels. If there are lots of rubber "chunks" the car has seen serious track time recently. :-) Not a bad thing but something to be aware of. Look to make sure it has the original wheels. They are very good wheels and are not cheap to replace unless you get a deal from someone on this forum. Look at tire wear, as our tires are also not cheap and are sometimes not available at installers.
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
markgws6 is offline   Reply With Quote
Old 06-01-2016, 08:26 PM   #7
Bauer2
Bauer2's Avatar
Drives: 2013 2SS/1LE and 2009 R1
One thing else I would check is the rims verify they are actually GM rims and not knock offs. Look for Camaro engraved into each rim.
Bauer2 is offline   Reply With Quote
Old 06-03-2016, 05:59 AM   #8
galvanizedcity
Thank you for all the responses everyone i will definitely check all that you have said
