Old 03-01-2015, 12:42 AM   #1
bcwolf
bcwolf's Avatar
Drives: 2012 CAMARO ZL1 COUPE
Torque Stearing
Anyone experience on moderate to heavy acceleration that the car seems like it wants to pull left or right for a moment?
I just started to notice a few months ago that when I give a little punch and the super charger kicks in the car wants to steer a little left. Tire pressure is good all the way around and tread is almost new. No adnormal noise, just a pull!
bcwolf is offline   Reply With Quote
Old 03-01-2015, 01:18 AM   #2
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
You are doing it. It's your body's reaction to the tightening of the sphincter muscle.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is online now   Reply With Quote
Old 03-01-2015, 02:58 AM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
torque steer is something that happens in a front wheel drive or all wheel drive vehicle. Unless there is a serious issue mechanically like a brake caliper that is stuck, it should be impossible in a rear wheel drive car.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 03-01-2015, 07:40 AM   #4
bcwolf
bcwolf's Avatar
Sven....I've tried it with no hands on wheel so it's not me or my body language.
Guess I need to visit the dealer but most of the techs at a Chevy store have trouble balancing a tire.
I think if a caliber were hanging up I would hear it under normal conditions. Also, the tires noise when I first start moving is incredibly loud until heat increases and it's around 60-70 degrees where I'm at. No idea if it's related?
Old 03-01-2015, 09:53 AM   #5
Sven59
HAMMER PILOT
Sven59's Avatar
That was a joke but I am sure it is true for some people. When I had the original goodyears the car would pull to the right or left but that was mainly the tires and the way they tracked and not necessarily under acceleration. I don't feel it as much with the MPSSs.
Old 03-01-2015, 11:26 PM   #6
blk 2013
blk 2013's Avatar
Drives: 2017 SS 6sp
this is normal when you hit gas with a quick punch the car wants to get side ways but tracktion control kicks in and pulls it back in line.
blk 2013 is offline   Reply With Quote
Old 03-02-2015, 09:56 AM   #7
boondocksaint
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla
A limited slip differential should distribute POWER evenly between two drive wheels. Traction is another matter, and even though PTM works pretty damn well, it's not instant especially when you're talking about PTM4 or PTM5. One tire may have 5% better traction, which would result in a perceived pull in either direction from a dig. Plus, the Goodyears like to tramline like crazy.
boondocksaint is offline   Reply With Quote
Old 03-02-2015, 12:24 PM   #8
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Definitely feel a pull when under full power. I am supercharged also and I was thinking there is driveline and body flex coming into play.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 03-02-2015, 12:34 PM   #9
kgendron71
REDHOT_ZL1
kgendron71's Avatar
Drives: 2014 Red Hot ZL1 M6
It may be tracking the surface of the road. Some streets are more crowned than others. Your tires will follow the curve in the road.
kgendron71 is offline   Reply With Quote
Old 03-02-2015, 01:40 PM   #10
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
Difference in pressure between the rear tires ?
ZL1 Camaro - Worlds Largest Sports Car
Road King - Not Garage Queen
2014CamaroZL1 is offline   Reply With Quote
Old 03-02-2015, 02:16 PM   #11
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
The half shaft on the right is almost twice the size, you have to wait for the Traction control to catch up..
ZMEnow is offline   Reply With Quote
Old 03-02-2015, 03:13 PM   #12
snapp32e
snapp32e's Avatar
Drives: '81-Z28/'07-Tundra/'12-ZL1/'13-Jeep
I agree totally with the erratic steering under hard acceleration. When I first bought mine I would drive with T/C shut off all the time. When you punched it, watch out. It was everything you could do to keep it on the road. Never mind your own lane. Finally one day I crashed it and did substantial damage to the suspension and driveline. After I got it back from the dealership it was a completely new car. Totally different beast. Straight as an arrow under full throttle. Even with the back tires on fire. Some of the components they changed were full front and rear suspension components on the passenger side, axles, rear end and the entire subframe. So I'm not sure what the issue could have been but I agree, they can be very sketchy with all the nannies shut off from factory anyways.
ZL1 #612
snapp32e is offline   Reply With Quote
Old 03-06-2015, 12:04 AM   #13
1ZL4FUN
1ZL4FUN's Avatar
Drives: Red Beast X2
I agree with this assessment. It's kinda scary at first if you don't realize what is happening. My 95 would just get sideways and you have to do the driving instead of the car. I tried to kick the tail out in the 2015 but it straightens itself up real quick. You can do it but you have to turn the features off. It's better to have them on in most cases.
New ride 2017 Cadillac CTS V-Sport. High Tech Twin Turbo Cruiser.
(sold then stolen) 2015 Red ZL1 M6 VIN: G1FL1EP5F9800197
FOR SALE 1995 Patriot Red 95Z28 M6 Project car. Less than 100k miles. 95 corvette motor. All good parts, too much to list. Just needs someone to put it together.
(sold) 2002 CHP camaro B4C
(sold) White 95Z A4 best 11.891 @ 114.269 boltons & weight reduction. Yes, it was a record. 11/13/02
1ZL4FUN is offline   Reply With Quote
Old 03-06-2015, 01:34 AM   #14
Sharp-ZL1
MSG,Retired US. ARMY
Sharp-ZL1's Avatar
Drives: 2012 ZL1, 11 XC 90, 15 BMW 328i SW
I had the same problem with mine. I would punch it and I would have to correct it from pulling to the left. After I changed the four rear subframe bushing I had no more pulling issues under acceleration. The right rear almost fell out when I started to remove it. The left bushing was very hard to remove.
My build site:
http://www.camaro5.com/forums/showthread.php?t=276256
2012 Camaro ZL1 #151, GCN, Dyno results 701 RWHP
Mods; 2.55 Pulley, CAI, LG Cam Package Ti Springs and 9G2X Cam, RX Can, KDI Heat exchanger, Hurst shifter, Orcale Ghosted marker lights, Kooks Long tube headers with Cats deletes and Tuned by Kraftwerks, Pedders 1 inch lowering Springs, Front and rear sway bars, Rear cradle bushing, BMR Trailing arms and toe rods.
Sharp-ZL1 is offline   Reply With Quote
