01-24-2013, 04:56 PM | #1 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
gm oil pump
Hi guys not to keep beating an old horse but my stock oil pump just took a dump after only 20000 miles. luckily it started making noise so I took it to the dealer to get it replaced under warranty before any damage was done. I did notice that oil pressure would drop at idle but didnt think anything off it, I tool it in cause it was making a tapping noise coming from the pulley. So for sure Im upgrading the oil pump when I do mods
Ported intake manifold and throttle body kooks 2" headers no cats
01-24-2013, 05:01 PM | #2 |
Im thinking I need to upgrade mine now that im starting to see these threads pop up. I have and early 2010 build.... Your description has given me some valuable information as far as what to look for thanks. Glad you didn't have any engine failures!
My Mod Journal <-- Its updated... again!
01-24-2013, 05:22 PM | #3 | |
Drives: 2015 c7 Join Date: Nov 2009
i honeslty do not think its a build or year thing. i mean hes a got a 2011. |
01-24-2013, 08:14 PM | #4 |
Drives: '11 Camaro 2SS/RS LS3 Join Date: Jan 2012
There have been numerous talks about these stock pumps going out in the LS3s. Had mine replaced just a few days ago when I had my cam put in.
01-24-2013, 08:25 PM | #5 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Melling 10296!
01-24-2013, 09:10 PM | #6 |
01-25-2013, 12:07 PM | #7 |
Drives: 2010 ss. 1990 RS the faster one. Join Date: Jan 2011
+2. I just put one in over Christmas. I also did a c5r chain, ls2 guide, 3bolt gear, and a trunion upgrade.
01-25-2013, 12:32 PM | #8 |
Drives: 2011 2SS/RS Join Date: Aug 2012
Is it mostly in LS3's?
01-25-2013, 12:44 PM | #9 |
The pumps in the L99s supposedly are more durable then the ones in the LS3's, so yes.
01-25-2013, 01:32 PM | #10 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
It is the bypass valve sticking in the bore due to the poor care taken in machining. They dont debur them and thats why far to many have issues. The Melling is my choice though.
01-25-2013, 04:11 PM | #11 |
V8 Lounge member #2
^^^Good man^^^
01-25-2013, 04:15 PM | #12 | |
V8 Lounge member #2
AND the rotor material and cover material do not mesh together and will actually gall and the rotor will occasionally weld itself to the cover. I spoke to a melling engineer personally, luckily he was a Gearhead. There are still other issues but its one of the reasons stock pumps fail.
01-26-2013, 03:51 PM | #13 |
+1
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
01-30-2013, 09:04 AM | #14 |
Drives: 2011 LS3 Join Date: Jan 2012
What are the signs and symptoms of this happening or knowing its going bad?
