Old 01-23-2011, 10:08 PM   #1
nl12
Drives: Unicycle
315 front tires, what would it take to make them fit?
315 front tires, what would it take to make them fit? I would like to be able to run 315 width all around. Specifically stock height 315 tires, I understand pedders runs 315s but in a shorter tire.
nl12 is offline   Reply With Quote
Old 01-23-2011, 10:53 PM   #2
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Pedders is using 305's on a 19 inch wheel. I doubt 315 / 20's will fit.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 01-24-2011, 01:10 PM   #3
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
You could make it fit, but only with the perfect offset. From what I remember about the Pedders setup, they worked directly with the wheel manufacturer to come up with an absolutely perfect offset for their setup. Keep in mind, they aren't running stock suspension components either.
rolnslo is offline   Reply With Quote
Old 01-24-2011, 01:41 PM   #4
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Fender flares. At least 1.6 inches wider on each side.
285 fits under the fender with stock springs and lowering springs, as well as Pedders coil-overs.
KW, Pfadt, BC coil-overs have less room than factory, those fit tight with just 275 tires up front and the perfect offset.
305, 315, etc... will stick out. The Pedders Camaro is a track test car, the front tires do stick out. At the track, this doesn't matter though.
Fquick.com/NineBall
Old 01-25-2011, 07:54 AM   #5
nl12
Drives: Unicycle
Fender flares would be cool, I'm trying to envision the car with wider fenders. I wouldnt mind getting some metal work done but I would want them to fit up with the stock front facia.
Old 01-25-2011, 08:37 AM   #6
LC
ou mai gad
LC's Avatar
Drives: SW 2SS x2
I ALMOST fitted a rear 22x11 with a 315/25 on the front ( COR offset )
As soon as some things arrive I will be trying 305 fronts...
LC is offline   Reply With Quote
Old 04-11-2016, 07:28 PM   #7
GHOSTRIDER-R
Drives: 2013 1SS, RS, Roof, Black on Black
Need answer has anyone done this? Will I be the first I just ordered 315/35r20 for all 4 corners
GHOSTRIDER-R is offline   Reply With Quote
Old 04-12-2016, 04:53 AM   #8
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
Talk to Pete at JPSS. He has at least two cars running 315's on all four corners.
mp51998 is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
315 tires mbmike18 Wheels and Tires Talk Sponsored by The Tire Rack 9 11-08-2010 02:41 AM
Recommendation for Skinny Front Tires Camcam16 Dragstrip and Launch Techniques Discussion 2 06-03-2010 06:54 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
No confirmation number? jamesc1123 Camaro Price | Ordering | Tracking | Dealers Discussions 12 02-21-2009 08:49 PM
