Old 03-29-2016, 06:33 PM   #1
SteveSneed
SteveSneed's Avatar
Drives: 2011 RS V6 Vert, 2017 Sportage SX-T
2011 V6: will CTS (*not* CTS-V) 2-piston calipers fit?
OK, I know most folks want the CTS-V (or Brembo/Wilwood/etc.) brakes. However, this is for a never-on-track, stock-engined daily driver V6 - I don't need $2K of brakes. But I would like a little better bite and less mush than the stock brakes provide.
So digging around on rockauto I find dual-piston front calipers for the performance package V6 CTS in my year for ~$70/wheel. The pad for them have about 20% more swept area than the stock Camaro calipers, and while they're not opposed-piston design they should do better than the stock brakes. So my questions:
* Do these fit? Will they require different rotors, or will they work on my 2011 2LTRS rotors?
* Has anyone done this swap? If so, what was your results?
Thanks!
SteveSneed is offline   Reply With Quote
Old 03-31-2016, 01:06 AM   #2
omgitsmiketuck
omgitsmiketuck's Avatar
Drives: 2011 LS V6 (M) & 2019 LS I4 (AT)
http://www.camaro5.com/forums/showthread.php?t=432631
The ATS calipers are a direct bolt on. You may need to cut the pan that surrounds your brake assembly, but otherwise it sounds like they're a 4 pot no brainer
2011 Camaro LS (MT) - Vitesse Throttle Controller / Flowmaster 40 Mufflers / CAI Intake / Apex scoop and washer relocate / Epic Engineering Catch Can / SS Stoptech Brake lines / BMR 1.2" Lowering Springs / IPF tune /Magnaflow X-Pipe / 25mm Mace intake spacer / BBK Long Tube Headers with High Flow Cats
(Current) 2019 Camaro LS I4 - Vitesse Throttle Controller / Mishimoto intake boot and charge pipes / K&N panel / BMR Sway Bars / GFB DV+ / ZZP Larger Throttle Body
omgitsmiketuck is offline   Reply With Quote
Old 03-31-2016, 09:37 AM   #3
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Another thing to consider to remove the "mush" from the brake system would be to install stainless steel brake lines & upgrade the fluid to a DOT4 like Motul RBF600. That would only cost you a couple hundred bucks.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 04-01-2016, 05:56 AM   #4
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
Just get a set of SS take offs. You know they'll fit.
mp51998 is offline   Reply With Quote
