08-07-2015, 03:23 PM | #1 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
REAR DIF FLUID SERVICE - DO 8 FIGURE 8's TSB - CHATTER
My 2014 ZL1 has 9,000 miles on it. I get 2 years free engine oil/filter service from dealership. Change engine oil light soon came on yesterday. Today I dropped it off at the dealership. Since it will be racked I asked if they can service the rear diff fluid also. The reason to service rear diff was to get out all that metal shavings out of the rear diff, other than that it worked great.
Service manager told me about a TSB rear diff fibrous clutch chatter. After replacing the rear diff fluid to drive the car in 8 figure 8's or 8 circles to the right and left right a way. If you do not do this it causes a dry spots on the clutch surfaces causing the chatter. I thought this was very interesting. Dimitri |
08-08-2015, 08:43 AM | #2 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
I would not worry about that. If you assemble a new differential or if you need to add the limited slip additive, you need to do some figure 8's after you add the additive. If you don't have "crunching" or "snapping" when turning, you are fine.
08-08-2015, 11:39 AM | #3 |
Dimitri
When you drain the fluid it leaves dry spots in between the fibre clutch packs. The dry spots causes slippage causing chatter. Doing a figure 8 or eight circles to the left and eight circles to the right gets the fluid in-between the clutch plates.
08-08-2015, 12:29 PM | #4 | |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
If you drain and refill right away, I'd challenge the "dry spot" theory. The ZL1 fluid already has the additive in it, and the fluid that's still on the parts has additive in it, so no...not buying that.
If you don't have chatter, you won't have to do this. Note what it says in red below. But here's the TSB that's being discussed for reference. Quote:
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
08-08-2015, 01:06 PM | #5 | |
Dimitri
08-08-2015, 01:20 PM | #6 |
Older Than Dirt
Now I'm interested in seeing that TSB. Got a number for it?
I've had all sorts of positraction GM cars in my lifetime and never saw a drain/refil/figure 8 and circle drive/repeat in a procedure unless you had chatter. If you drive it around town after a regular fluid change, you'll do plenty of turns and accomplish the same thing.
08-08-2015, 01:52 PM | #7 | |
Dimitri
08-08-2015, 05:08 PM | #8 |
Drives: 2011 Summit White Camaro SS (LS3) Join Date: Sep 2014
I visited my Service Managers house where he has a lift so I could do my tranny and diff fluid. He just told me to drain the old fluid out, push in half of the new fluid, put the additive into the half bottle of fluid and shake it up. Then push that into the diff. Did that and left. It's been a week and I don't have any problems and didn't do any figure 8's.
J |
08-09-2015, 06:30 PM | #9 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Changed fluid in many a differential.......never done anything but drain, fill and drive. Never an issue.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
08-09-2015, 10:46 PM | #10 |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
