12-27-2015, 01:35 AM | #1 |
Ultron
Drives: 2014 UPP TT Join Date: Jan 2014
Turbo Header Question
I have two holes/ports in the Left turbo manifold.. Both were not used.. I am smelling fumes when I really get in to boost, and I believe I hear a leak. Also My car idle sounds different since I moved to Cali from VA.
1q Will I need to retune because of the move? 93 octane vs 91.. 2q What is the second port for in my manifold? 3q Anyone know what the weird sound from my car at Idle? posting videos and photos..
2014 UPP Twin turbo, 376 LSX B8, Custom stingray lip kit, Z28 spoiler wicker bill, BC coils, LSR sways, Zl1 Strut brace
IG: abosulte_jacoup |
12-27-2015, 01:49 AM | #2 |
Ultron
Car at idle
12-27-2015, 02:59 AM | #3 |
Tri-County Camaro SWFL
I'd suggest adding an octane booster like Torco for the difference in octance. A retune probably isn't required but it would help the car run better.
I'm going to go on a limb and say one port is for an o2 sensor and another is for wideband. And the ticking sounds like a lifter or something else in the top end Edit: I don't have any FI so what I say could be wrong. Somebody far more knowledgeable than I have will comment.
12-27-2015, 03:22 AM | #4 |
Ultron
Thanks for the feedback.. Just want to get an idea before I got yo a new shop, and they want to charge my lots of money.
12-27-2015, 08:57 AM | #5 |
Drives: it changes Join Date: Nov 2010
Tune should be checked, and it would make sense to have it adjusted if that's the fuel you're stuck with using.
And light ticking noises like that are indicative of an exhaust leak pre-turbocharger. Get a piece of tubing and use it to your ear like a stethoscope to try and trace where it's coming from if there are no visible signs of a leak. Problem with wrap, is it can hide the signs and wrap does encourage stainless etc to crack and fracture. |
12-27-2015, 09:48 AM | #6 |
Get tune checked before getting on it. I would say 99% chance you need the tune dialed down a bit because of the 91 octane. West coast gas really is junk.
Nick
Corvette Z06 -1200ish rwhp |
12-27-2015, 02:13 PM | #7 |
Ultron
Ok thanks guys for the info...
12-27-2015, 09:47 PM | #8 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
look into torco accelerator. add a can or two every time you fill up to bring octane level up. still recommend dyno to check tune
exhaust leaks are not that hard to find look at all connections for burnt exhaust wrap or traces of black exhaust soot
12-28-2015, 12:16 AM | #9 |
Too much is never enough!
Yes, one hole for the Narrow band, and one hole for the wide band. I hear a lifter ticking but its just an exhaust leak. You can also use a broomstick handle, or long screwdriver to listen for the leak like a stethascope, just like stevieturbo said, if you dont have any tubing. Maybe another video with some light throttle changes to hear better would be helpful.
