01-03-2016, 02:36 PM | #1 |
Drives: 2014 Camaro SS Rs Join Date: Aug 2014
Gauges
What gauges/contollers (brand specific) do yall recommend with a new turbo build?
01-03-2016, 09:31 PM | #2 |
I'm running a g force 2 boost controller, and as well a dash logic for boost ect. To be displayed in my hud and dic in the dash, the boost controller I would highly recommend, and I would only recommend the dash logic unit if you didn't want to have your guages visible, it's a very neat system but seems to freeze up alot plus I would recommend a wideband 02, I run a PLX Wideband Air/Fuel Sensor Module in mine, good luck luck with your build and what are you goals on your build?
01-03-2016, 10:14 PM | #3 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
heres my set up https://www.instagram.com/p/8-1mdvNr...-by=b00sted_ss
gfb boost controller aem wideband aeroforce interceptor scangauge
01-03-2016, 11:18 PM | #4 |
Too much is never enough!
I would have AFR and Boost at a minimum. If you can add fuel pressure, that will be important also.
I use AEM Truboost and AEM wideband AFR Ill be adding fuel pressure to my setup. But other than that, I like the way it is now. Too many gauges and then its too much to look at and pay attention to while your trying to keep the car straight from a dead stop to speed. I prefer to data log my critical details, review them once I have the chance and its safe to do so. The gauges are mainly just there for security.
01-04-2016, 07:08 AM | #5 |
AEM boost gauge
AEM wideband Go Fast Bits boost controller.
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
01-04-2016, 07:36 AM | #6 |
OMWTFYB
Drives: ZL1 Join Date: Sep 2011
Can you post pics of you D I C screen using the dashlogic
01-06-2016, 12:32 PM | #7 |
Drives: G8 Join Date: Mar 2012
I just ordered the Innovate SCG-1, its a WB and boost controller in one. The other two slots will have an oil pressure and temp gauge in (I have a G8 with the center stack triple cluster).
Is anyone here using an Innovate product? |
01-06-2016, 12:53 PM | #8 |
I have used innovate in the past they make solid stuff
01-06-2016, 02:30 PM | #9 |
One man Army
Drives: 1987 Iroc Players car Join Date: Jan 2015
I have the PLX dm-100 it shows air fuel and boost in the same gauge. Very slick setup. I would post pics but I don't have it in this car yet. I have had these in other cars and they work great. You can also run it as a scan gauge or monitor any ODBII info from your car. For turbo you will want a boost controller also. I will supercharged no boost controller needed.
1987 Iroc-Z with a turbo 5.3, T-56, Moser 9", and lots of other goodies.
http://www.mifbody.com/vbulletin/sho...87-IROC/page24 2010 Camaro 2SS/RS with a K&N cold air Stainless Power headers, Magnaflow cat-back, staggered TSW Nurburgring's just a great daily driver. |
01-06-2016, 02:31 PM | #10 |
One man Army
01-06-2016, 02:52 PM | #11 |
'It's an experiment'
AeroForce Interceptors -- duals:
-Don
747 RWHP 794 RWTQ
