05-29-2014, 02:23 PM | #1 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
K&N oil filter leaking?
I have the SS 1LE in my Sig.
I had an oil change done on my car, and I had bought a K&N oil filter for it. After it was installed and oil filled, the car was okay for about 4-5 days. Then I started noticing a smell like burned oil. I looked under and on the engine and did not see any leaks. Then 2 days ago I noticed an oil puddle under my car, but I live in an apartment and just though someone else parked there. Yesterday the puddle was bigger and when I looked underneath again I noticed oil leaking from the filter. So I went back to the place and had the guy tighten it 1 more turn with a wrench. I've never had this many problems with them in the past...Agh. Anyway after adding some more oil, I now still smell it but I don't see as much oil coming out (if any). Since I'm going to the track in less than 2 weeks though, I want to be sure this is fixed. Anyone else had this experience with a K&N filter? Does this sound like a defect or installation issue?
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
05-29-2014, 02:25 PM | #2 |
BTW, it's cool on the 1LE and probably ZL1, you can see the filter through the front wheel.
(1 of 43) |
05-29-2014, 09:08 PM | #3 |
Drives: '13 1LE, '89 Caprice Join Date: Jul 2013
I use K&N too but never had a problem. Maybe the guy screwed up the gasket.
05-30-2014, 03:14 PM | #4 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
Two things come to mind
1. When he removed your old filter did he make sure the old filter gasket was not still stuck on the block and did he wipe it clean with a rag. 2. Did he put engine oil on the new filter gasket tightening it to 3/4 of a turn past of when it first touches. K&N make great products. |
05-30-2014, 03:27 PM | #5 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
I would only use a OE filter, an aftermarket filter and oil problem will be denied at the dealer level. Nothing wrong with aftermarket, but OE filters are tested for flow an filtration for the application.
05-30-2014, 04:32 PM | #6 |
Hmm, now you have me wondering what the difference in flow between the two are. I think OE filters to 30 microns and the K&N is at 10. I wonder how that effects flow.
05-31-2014, 10:30 AM | #7 |
I went to the dealer and had them take off the K&N and put on a stock filter and refill with full synthetic. They saw the leak and said they thought it was coming from the filter but did not say anything else... So I guess I'll never know now. If Ihad some ramps or better way to get my car in the air, I would do it myself.
(1 of 43) |
05-31-2014, 11:40 AM | #8 |
05-31-2014, 12:12 PM | #9 |
Dimitri
ramps are awesome
06-14-2014, 04:34 PM | #10 |
Drives: 2014 1LE, CRT, Recaros, NPP Join Date: Mar 2014
I just had the same problem with K&N. Changed oil at 1k miles and put on K&N. Leaked like the OP said. No previous gasket residue and hand tightened like I always have on every other car I've had.
I tightened it down with a wrench and the K&N nut but I don't think this should be necessary. We'll see how that works. Any more advice? |
06-25-2014, 04:30 PM | #11 |
Drives: bicycle Join Date: Jun 2014
Heard of to many leaks with those filters. Purolator is a good brand also.
We AMSOIL have a synthetic media filters that is very heavy duty, part number is EAA15k50 |
06-25-2014, 04:36 PM | #12 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
And yes, the Purolator Pure-1 is an awesome filter. It's all I use now. |
06-25-2014, 06:27 PM | #13 |
COTW 5/06/2013
Guess I should have been more specific, if the oil problem is related to a flow problem with the filer, it can be denied. If the internal part of a OE filter failed, it would still be covered. Does not matter to me either way, just easier not to have to deal with that.
07-04-2015, 09:15 PM | #14 |
ruff ruff
Drives: 2010 2SS/RS Join Date: Dec 2006
reviving old post, but I just changed my oil last week, wasn't my ss, but my wife's turbo optima, I put a k&n on and a few days later saw oil line in driveway, looked under car and oil was leaking from the k&n filter safety strap hole, then I went online and seen many issues with these filters. I was always a fan of everything k&n, not anymore. I will never buy a oil filter made by k&n after this incident and reading reviews on amazon and seen many have had same issue. The racing safety strap hole is on that nut built into the bottom of the filter for easy removal, not sure how k&n is messing these up, but is either bad welds inside or when the safety strap hole is drilled, they drill too far into the filter. I rarely complain, but if I didn't see the oil line in my driveway I could have had a blown motor, low oil and turbos don't mix.
2010 2SS/RS, XO Verona wheels, BC coilovers oem ZL1 bumper conversion Kenwood ddx9905s, maestro, Kenwood xr1s, xr4s, kappa 1200w,subs, Kenwood xr comps and rear deck speakers, long tubes, hf cats, speed secrets tune, custom exhaust, CAI, blacked out everything.
