01-09-2014, 07:24 PM | #1 |
Drives: 2013 Camaro ZL1 Join Date: Nov 2012
Swapping LSA cam to LS9
Looking to do the cam swap to LS9 in a couple months and I'm curious if people who have done the swap like it. And what springs were used, LS9 from what I've read, and if they held up well over time. Looks like the LS3 and LS9 springs are the same and LSA are different from the two. Retainers are the same on all 3 engines. Worked well in my 1LE with SC bolted on but didn't do a before and after on just came since I installed cam before SC.
I know there are threads on this but they are older, so just looking for some current data and maybe some specifics if possible. And yes, an aftermarket cam will net more power, but I love GM reliability and the price since the cam already sits in my toolbox in original box. And, an aftermarket cam is north of $700-$800 with good springs. Also labor isn't an issue because I'm installing it myself, so 30-35hp for under $200 for cam and springs is Ok in my book. Thanks for any and all opinions in advance!!
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance 1000rwhp Last edited by white1LE; 01-09-2014 at 07:25 PM. Reason: wording wrong |
01-09-2014, 08:38 PM | #2 |
Drives: 2013 ZL1 Ashen Gray Join Date: Oct 2013
The LS9 springs are the same part# as what is in the ZL1
I'm probably going to do this in the spring but I'm not swapping springs. And the retainers are not the same the LS9 are different.
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience. 754 RWHP 747 RWTQ 93 Octane http://www.camaro5.com/forums/showthread.php?t=347243 |
01-09-2014, 08:56 PM | #3 |
Damn!! Guess when you want something done right you need to do it yourself. I work at a dealership and had one of the parts guys compare #'s for me. Will verify what he looked up in the morning.
Thanks for clarifying!
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance 1000rwhp |
01-09-2014, 09:07 PM | #4 |
01-09-2014, 09:27 PM | #5 |
Drives: 2016 Corvette Z06 M6 Join Date: May 2009
I did this swap a few months back. I used PAC 1518 valve springs.
I like this cam because it obviously adds power, but basically feels/sounds completely stock as you would expect.
2013 Dodge Viper #44/150 Launch Edition IG:@absoluthank
20/21 BC Forged Wheels : BC Coilovers: TA Aero |
01-09-2014, 09:54 PM | #6 |
20/21 BC Forged Wheels : BC Coilovers: TA Aero Last edited by AbsolutHank; 01-09-2014 at 10:06 PM. |
01-09-2014, 10:03 PM | #7 |
No Hank is wrong, the LSA is a single bolt the LS9 is a 3 bolt
01-09-2014, 10:06 PM | #8 |
Correct! I don't know why I read that as LS9
Fixed it above...don't want to spread misinformation
01-09-2014, 10:21 PM | #9 | |
You can use your stock chain tensioner if you want to.
01-09-2014, 10:25 PM | #10 |
I used the LS9 cam gear and stayed with the factory tensioner
01-10-2014, 09:00 AM | #11 |
Drives: 73' VW Bug Join Date: Sep 2008
The LS9 has lighter valves. You should upgrade your springs.
01-10-2014, 09:04 AM | #12 |
You only need to upgrade your springs if you are going to turn up the boost.
01-10-2014, 04:46 PM | #13 | |
LS9...Springs #12625033 Retainers #12596508 LSA...Springs #12589774 Retainers #10166344 LS3...Springs #12625033 Retainers #10166344 So I was wrong about the retainers, they do have a different part number. But the springs are definitely different. For the people using the LS9 springs, are they working/holding up well?
13 ZL1 A6
01-10-2014, 05:48 PM | #14 |
Your wrong on the LSA spring.
Here is one of MANY GM parts dist.it matches the LS9 spring This quote was right off LPE web site "The LS9 springs that don’t meet the 1.190” specification are also available from LPE at a lower cost, GM PN 12625033" http://www.chevroletonlineparts.com/...rings/12625033
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience. 754 RWHP 747 RWTQ 93 Octane http://www.camaro5.com/forums/showthread.php?t=347243 Last edited by Baer383; 01-10-2014 at 06:00 PM. |
