Old 01-06-2012, 05:23 AM   #1
SteveRS
SteveRS's Avatar
Drives: 2010 SIM Cobalt SS
Send a message via AIM to SteveRS
SS exhaust swap for ZL1?? i know someone is going to try ;)
this is a repost but I lost the thread months ago.. so im making a new one..
aside from the diffuser being different to accomodate the quad tips... will this theoretically work?? or will I have to get some other mods like some sort of cpmputer programming for the valves or somethin.. ill run with them open at all times.. doesnt bother me haha
2011 Imperial Blue 1.5SS
2010 Silver Ice Cobalt SS
SteveRS is offline   Reply With Quote
Old 01-06-2012, 09:15 AM   #2
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
I'm thinking of doing the same but the valves are controlled by the cars main computer. I dont know if that software can be added to previous ECU's. Even if you could your car would have the necessary wiring. What I've been looking at is the Mild to wild exhaust control kit from West Coast Corvette.
http://www.westcoastcorvette.com/p-1...-c6z06zr1.aspx
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 01-06-2012, 09:21 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
What I would worry a little about would be the size of the pipes aft of the cats' and then how it fits against and around the rear pumpkin, being it's a lot larger on ZL1. The bodies of the mufflers are significantly different between the two (for obvious dual-mode reasons) but the bends aft the pumkin are more aggressive on ZL1. It seems like it would work, but I'd just anticipate checking these areas for any problems. Otherwise - I bet it'd be a nice fit
'20 ZL1 Black "Fury"
Old 01-06-2012, 12:16 PM   #4
stymie
stymie's Avatar
Drives: 2012 Chevrolet Camaro ZL1
How about programming the in-car HOMELINK system to control the valving... ?
stymie is offline   Reply With Quote
Old 01-06-2012, 12:20 PM   #5
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
I am definitely going to be doing this swap. If I'm correct the dual mode exhaust on the corvettes run off vacuum. My '12 SS should have some of the Zl1 provisions already in tact.
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 01-07-2012, 04:42 AM   #6
SteveRS
SteveRS's Avatar
I remember seeing a dual mode exhaust up close when i was at a chevy dealer gettin work done on my cobalt SS revving below 4K it was fine then he let it rip and it opened up higher than 4500-5000 RPM..was a nice sight.. I mean n theory its not liek the ZL1 is a WIDER camaro.. and all camaros come off the same frame and platform so im sure this exhaust will mount up just fine.. we just need a good under body shot of a ZL1 LEGIT.. to see what the mufflers look like
Old 01-07-2012, 10:37 AM   #7
nak3dsnake
nak3dsnake's Avatar
Yes there's another kit that will let you.
http://shop.sunsetorangecreations.co...1&categoryId=2
Old 01-07-2012, 10:40 AM   #8
nak3dsnake
nak3dsnake's Avatar
Its an issue of whether or not the tubing is 2.5 inch diameter or 3 inch diameter that so have speculated it might be. If its 2.5 it'll bolt right up, if not it'll require some adapting.
Old 01-07-2012, 10:46 AM   #9
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
I don't think its worth doing. you'd be better of with an aftermarket cat back IMO.
Old 01-07-2012, 10:50 AM   #10
nak3dsnake
nak3dsnake's Avatar
Except people want it for the dual mode part of the exhaust. And last time I checked there wasn't a dual mode kit for our cars, and a pair of dual mode mufflers are about 800 bucks a pair. I suppose you could get a set of baffles and do it yourself but that's not what people here want. So getting a take off exhaust from a ZL1 looks like the better deal.
Old 01-07-2012, 11:03 AM   #11
Rogey89
ZL 1 3 7
Rogey89's Avatar
Drives: '23 ZL1
I don't think adding the ZL1 active exhaust to the SS is a good idea
'11 2SS / '23 ZL1 / '23 Silverado ZR2 Daily
Rogey89 is offline   Reply With Quote
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
I'm 16 (2010 Camaro SS) and want headers and loud exhaust, what should i get? DuhKoDuh Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 85 09-12-2011 10:04 AM
MBRP Exhaust Review For My SS ilovemy2ss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 07-25-2011 09:46 AM
2LT exhaust options Guardian1816 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 3 01-12-2010 09:28 PM
(UPDATED) Stainless Works exhaust and header systems!! (Tag's SS w/ HP #'s) Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 162 07-09-2009 06:39 AM
