07-01-2014, 08:07 AM | #1 |
Drives: 2010 1SS Join Date: Jan 2013
Best versatile single sub set-up for music.......
What's the best single sub set-up for music like Jazz, R&B, and Rap?
07-01-2014, 10:03 AM | #2 | |
Drives: 2014 2SS RS Coupe Join Date: Aug 2013
This is very difficult to answer. Honestly I'll go through the whole thing. It's really personal preference. I love my music low. Therefore when I buy a subwoofer in look at the frequency response of the subwoofer. The lower the better the FS is based on the enclosure volume that the sub is in. Typically the larger the volume the lower the box is tuned to (if ported) so it's all personal preference. Low FS means high enclosure volume ft cubed air space. Then you'd have to either buy or build a box to match the subs FS. Or buy a prefabbed box that's sealed and get any sub and any amp because at that point you're only going to be worried about RMS because all subs are going to play pretty close the the exact same note in a sealed box but it's much easier to work with and the note will play louder depending on the wattage rms the subwoofer takes.
07-01-2014, 10:57 AM | #3 | |
thanks bro. It's been a while since I did a complete system install. With so many choices out there, I'm at a crossroad.
07-01-2014, 11:16 AM | #4 |
The most popular power subwoofers are JL 13w7, Rockford Fosgate P3, Kicker L7, and Alpine Type R. Google the specs for these and look at FS response, the lower the number the better they are. That's how I buy my subs.
07-01-2014, 11:27 AM | #5 |
07-01-2014, 12:02 PM | #6 |
07-01-2014, 12:29 PM | #7 |
07-01-2014, 02:01 PM | #8 |
Drives: 2018 Ford F-150 Lariat 4x4 Join Date: Mar 2012
WHat about a good 10" sub that will fit in the stock Vert position??
1999 30th Anniversary Convertible Trans Am
2001 SOM Convertible Trans AM 2012 2SS/RS Summit White Convertible My Build Thread: http://www.camaro5.com/forums/showthread.php?t=224339 |
07-02-2014, 05:39 AM | #9 |
Drives: 2013 1LS, 2013 Ram 1500 Join Date: Mar 2013
i also listen to all types of music. i have always been a fan of sealed built to spec for the sub.
