10-21-2010, 08:50 AM | #43 |
Drives: Lexus GS300 Join Date: Oct 2010
Thanks guys, I am another installer working on Mr. Robertson's Camaro and the one taking all these pictures.
Here are some updates: Tinted the sidemarker lenses as well as the backup light lens one coat after 3 coats. this left the darkest tint without shutting out all the light. wiring for the trunk dyed the trunk liners black to match the new trunk set up amp rack in red suede more suede red LED's in and amp rack faceplate fitting mock up with the lights on mock up again had the car back up on jack stands to do the led under body kit there will be more additions soon. the ipad mount is taking shape and there are a few more goodies we need to work on. -Tony |
10-21-2010, 10:19 AM | #44 | |
Drives: XK 4x4 Ordered '11 2SS/RS SW LS3 Join Date: Jan 2010
I want to do this to all my lights as well. You can't put tint or a cover over them in this state as it will not pass inspection. Thanks! |
10-21-2010, 06:26 PM | #45 |
10-21-2010, 06:30 PM | #46 |
That speaker light-up design looks similar to another camaro...
10-21-2010, 08:06 PM | #47 |
do you have any pictures? we haven't seen many other setups yet. tried to keep it simple and clean but make is showy too
Tony Van Nguyen
Car Audio/Performance Specialist (Shop to be named later) Team International AllStars |
10-21-2010, 08:54 PM | #48 |
10-21-2010, 09:03 PM | #49 |
Drives: 2011 Camaro LS Join Date: Sep 2008
After you were finished spraying the side markers etc do they look like someone went and painted them or do they actually look pretty good on the car?
10-21-2010, 09:27 PM | #50 |
Drives: not what you're thinking Join Date: Sep 2010
If done correctly they should look factory and just blend right into the car. In this case we had to point it out to the vehicle owner because they just blended in and thus were reletively unnoticeable.
Scott Paterson
Car Audio Specialist (Shop to be named later) 2009 MECA SQ Modified Street World Champ 2010 MECA SQ Modified GA State Champ |
10-22-2010, 03:45 PM | #51 |
10-25-2010, 06:24 PM | #52 |
Drives: '14 Blade Silver Z51 Join Date: Jun 2009
Any updates on this?
Say When
10-25-2010, 07:59 PM | #53 |
yes, we've been waiting on a few parts and had some other projects come up as well. we have found a new location for the hvac controls. keep checking in!
Tony Van Nguyen
10-25-2010, 09:55 PM | #54 |
So as Tony said, there will be more updates coming, but really there isn't much we can show right now. Frankly the audio system is done, the body kit is done, the grilles are done, the led lighting is done, custom on star retention is done, and really the only other major loose end to be tied up is the Ipad mount and one other minor surprise. We decided to incorporated the HVAC controls into Ipad peice just the other day so that readjusted schedules a touch.
Also we are exploring patent and mass production options of the piece so we are probably going to have to withhold any more pics of the actual Ipad build until final decisions are made. All that said, keep an eye out b/c this car is rowdy and we want to share it here first (well after the ower gets it of course) before it starts showwing up in publications. . . .
Scott Paterson
10-25-2010, 10:42 PM | #55 |
If you guys patent and produce that iPad mount, I will be first in line. That sounds amazing.
10-25-2010, 10:56 PM | #56 |
Drives: Getting 2010 Camaro Join Date: Jul 2008
If you can produce a IPad mount for the camaro and intergrate the HVAC controls into the IPad I will be first or even second in line
Similar Threads | ||||
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! | RPI Designs | Cosmetics and Lighting Modification Discussions | 36 | 04-02-2020 05:32 PM |
Camaro SS: All Out Bonneville Unlimited Speed Test | Tran | 5th Gen Camaro SS LS LT General Discussions | 75 | 08-23-2010 02:49 PM |
Installation Camaro Needed for Manual for a Justice Install Package in SF Bay Area | Info@PeddersUSA.com | USA - California | 6 | 04-30-2010 08:02 PM |
Im sure this has been asked before.. But forgive my innocence :) | gmag21 | Suspension / Brakes / Chassis | 23 | 02-21-2010 10:29 PM |
