Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Southeast
Old 12-15-2011, 02:33 PM   #1
MTI Racing
MTI Racing's Avatar
Drives: 2010 Camaro SS
(Day 4) - The Twelve Days of Christmas Techinical Posts - a New Product Everyday!!
CAMARO POST
Commercial Thread Here:
http://www.camaro5.com/forums/showth...97#post4170597
Merry Christmas!!!
MTI Racing is highlighting a new product each day to show you the benefits and features of some great products on the marketplace.
"On the Fourth day of Christmas, my true love gave to me..."
Today’s demonstration for Thursday Dec 15th is…
Check out this Video:
1) MTI Racing Brake Lines Corvette (C5/C6/C6Z)
2) MTI Racing Camaro Six Shooter Premium Shifter (5th Gen V8)
CHECK OUT THIS PRODUCT INFO:
MTI Racing Six Shooter Shifter for Camaro
http://www.mtiracing.com/Purchase/Ne...Camaro-V8.html
The MTI Racing by UUC Six Shooter Shifter is engineered with better materials, shorter throw, and a better overall feel. Now you can get rid of that stock numb, rubbery factory shifter and replace it with the Six Shooter Shifter and confidently go through the gears with precision. The throw is reduced by approximately 25% and a HUGE improvement in feel. It feels like 1000% improvement.
The stock OEM shifter is made using a 4-pc shaft that is bushed with rubber, a pressed-on ball joint, and a welded-on pivot that holds a shaft bearing attached to rubber linkage bushings. The new MTI Racing Six Shooter Shifter is made of high quality stainless steel with a 1-pc ball machined directly into the lower stick, and a roller bearing at the base shift rod link. The kit also replaces the stock rubber bushings with durable delrin composite bushings, increasing the overall strength and life of the shifter assembly. The Six Shooter Shifter requires little to no extra effort when shifting, and instills confidence with its solid structural feel. Mission accomplished.
The MTI Racing Six Shooter shifter kit is not an entire shifter housing replacement. The kit includes all the components to convert the shifter assembly and its internal hardware with the highest quality components, while retaining the factory housing. Installation of the shifter requires the transmission to be lowered slightly to remove and install the shifter assembly. The new shifter is designed to use the stock shift knob or an aftermarket knob. The throw reduction is around 25%. We have tested over and over different throw reductions, and we felt that the final version provided the best overall confidence in shifting. Made in the USA.
Corvette Brake Lines:
http://www.mtiracing.com/Purchase/20...ake-Lines.html
Superior Stopping Power
MTI Racing stainless steel brake line kit for 2005+ C6 and 2006 + C6 Z06 Corvette. Hi performance, D.O.T. approved, direct bolt-on replacement. Reduces braking distance, no more spongy brake pedal feel. Will not interfere with the ABS braking system. Lifetime warranty.
This upgrade is recommended for any street Corvette that wants to have a better brake feel with an added safety benefit. If you do any mountain driving or trackdays, these brake lines make a difference you can feel.
For more information, please visit this commercial thread HERE:
p.s.
*If you happened to eat too much Holiday Fruitcake and missed today’s info, check out our Facebook page.
Merry Christmas!!
MTI Racing is offline   Reply With Quote
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 11:00 AM
5th Gen Christmas Dollar Days!! Info@PeddersUSA.com Suspension / Chassis / Brakes 36 12-20-2009 12:01 PM
2010's Sold Out ! carguy 5th Gen Camaro SS LS LT General Discussions 53 12-06-2009 01:12 PM
IMPORTANT Part 1 Warranty Disputes Zeus Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 08-25-2009 11:37 AM
Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 85 07-26-2009 05:20 PM
