03-19-2013, 01:50 PM | #1 |
Drives: 2021 Yukon Denali, 2018 ZL1 Join Date: Feb 2009
L99 Resonator - Replace with X-Pipe
I have an auto 2010 Camaro (L99) with Kooks Headers, Hi-Flo cats and SLP Loudmouth II mufflers in rear ---- with the big stock center resonator. This combo produces the sound I like along with a little extra hp. (AFM has been tuned out).
BUT that big resonator has developed a "rattle" inside (I believe this is common for some early models). Apparently the baffle welds let go. I plan to replace the resonator with a X-Pipe (see JEGS). Has anyone with a similar L99 setup done this?? I wonder if this will induce drone. Any input is welcome.
2018 ZL1
03-19-2013, 01:57 PM | #2 |
Drives: pleather and Chiclets Join Date: Mar 2012
it might up the drone factor. but if you like the tone and not the drone j-pipes are what you need. kills drone at the desired frequency
03-19-2013, 02:03 PM | #3 |
Thanks for the info, I have zero drone now and was hoping the X-Pipe didn't create significant drone. J-Pipes would be my Plan-B, if needed.
2018 ZL1
03-19-2013, 02:07 PM | #4 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
I changed my resonator for an x-pipe and the exhaust tone became a bit raspy, I then went with a resonated x-pipe and it sounds much better.
03-19-2013, 02:07 PM | #5 |
its what i would do and is proven to work as long as you match up the length of the j pipe correctly with the frequency.
03-19-2013, 06:57 PM | #6 |
Choke on that causality!
Drives: 2010 2SS/RS Join Date: Sep 2009
I have the L99, headers, no cats, stock mufflers, no AFM, no DOD. I replaced the resonator with an X-pipe and it made almost no sound difference at all and did not introduce any drone. Perhaps its the stock mufflers that prevent it. It can't be any other part of the exhaust since I replaced all of it.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
03-19-2013, 07:07 PM | #7 | |
2018 ZL1
03-19-2013, 07:17 PM | #8 |
Banned
Drives: ss camaro Join Date: Jul 2012
i used a summit xpipe and couldn't be happier, but I do not have headers though
03-19-2013, 09:28 PM | #9 |
Drives: 2011 2SS Join Date: Jan 2013
I have muffler deletes and the Jegs x pipe. Drone only under half throttle. I am going to add some glasspacks behind the x and before the axles.
03-20-2013, 12:41 AM | #10 |
03-20-2013, 06:18 AM | #11 |
Drives: 2010 CAMARO TURBO SS Join Date: Jul 2010
I have a friend that has done this exact set up from Jegs, he has never mentioned drone, I have not yet rode in it since he did it so I cant say for sure, but the owner really likes it.
