04-21-2016, 09:12 PM | #1 |
Coolant Temp??
I have been reading a few threads regarding the specifics of coolant temp. I drove to work today and the car sat for 5 hours but it had been driven earlier throughout the day for errands and such. The car I drive is a 2012 Camaro 2LS I did my normal startup as usual let it idle for a minute or so and drove it easy for maybe 6-8 minutes. Coolant temp was around 176 degrees and a large dump truck got right in front of me and started to release a hail of rocks as we all know are the enemy of a clean chip free windshield. I was in manual mode and mashed the gas and it revved to around 6k rpm before I shifted. This all leads to my question was it okay for the engine to be floored like that with the coolant at 176 degrees? I tracked the digital readout and also the needle was almost if not exactly where it normally sits. I'm kind of freaking out over this because I'm not trying to cause any unnecessary wear and tear on this car I just bought. Thanks for any comments!
04-21-2016, 09:18 PM | #2 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Should be fine. More important is engine oil temp rather than coolant temp.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
04-21-2016, 09:21 PM | #3 |
Drives: 2014 SS Join Date: Apr 2015
176? Isn't that normal?
Mines usually right at 191
Toys:
2014 SS - TSP 235/239, CAI, LT's, 12.2 @ 115 ("SLOWLY" chipping away ET) 2000 Trans Am - Bolt-ons 13.0@110 (sold) 2009 YZF R1 - Race bike (road course)(totaled racing) 2008 YZF R6 - Race bike (road course)(still own) |
04-21-2016, 09:24 PM | #4 |
Normal operating temp is 201 for me.
04-21-2016, 11:02 PM | #5 |
Cruising is generally around that area and idle rises about another 10 degrees. Like the other post above mentioned
Engine oil temp is more important and it was nearly there I wouldn't have floored it had I known I still needed to warm up more. Its so hard to judge by that needle because of the way it sits. But I was certain I just wanted to be sure that I haven't really harmed anything to bad. If anything it was 90% warm/ready worst case scenario. |
04-23-2016, 08:33 PM | #6 | |
