10-13-2014, 05:26 PM | #1 |
Jackstand fear
I'm fixing to be installing a short shifter, catback, and headers, and I no longer have access to a lift. I have to say I'm frightened of jackstands. Anyone do their work on stands or ramps? Any pointers?
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list: Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket. |
10-13-2014, 05:28 PM | #2 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Put them under the frame only, if it makes you feel better, leave the jack under the car too
10-13-2014, 05:34 PM | #3 |
Drives: 2011 ss camaro Join Date: Jan 2013
I did my lsx and 4l80e swap on jack stands. Just make sure you have them in the right location for the work you are doing and you will be fine. I usually leave the jack under the as well
10-13-2014, 06:38 PM | #4 |
I will be doing the short shifter first so do you recommend all 4 corners or just the front 2?
10-13-2014, 07:23 PM | #5 |
Drives: 2010 Silver SS/RS LS3 Join Date: Nov 2011
Pick up some rhino ramps from autozone, I did my short shifter install using ramps.
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB. Rhino79 Dyno tuned...405 HP/399 TQ |
10-13-2014, 07:33 PM | #6 |
Drives: 2011 SS (Sparrow Spearer???) Join Date: Aug 2013
i use stands. i also leave jack(s) with a little weight on them. also have my wife check on me often, just in case
Black magic woman, don't turn your back on me baby!
10-13-2014, 07:37 PM | #7 |
36.58625, -121.7568
Use jackstands all the time. Put it up. Shake the vehicle a little bit. Shouldn't move at all if you did it right. Should be like a rock.
10-13-2014, 07:38 PM | #8 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Rat trap
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
10-13-2014, 07:41 PM | #9 |
Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
Ramps and jackstands work. I don't have access to a lift but I use that stuff all the time. I used that stuff to install my shifter as well.
10-13-2014, 07:44 PM | #10 |
Drives: 2011 Camaro 2SS/RS Convertible and: Join Date: May 2014
If you are only lifting front of back at a time, make sure you chock the remaining ground wheels.
Currently in my Garage: 2011 Camaro 2SS/RS Convertible | 1980 Corvette Stingray | 1981 Firebird | 1968 El Camino | 2007 Crown Vic Police Interceptor | 2001 Silverado | 2001 Blazer | 1965 Chevy C-10 | 2007 Harley Softail Custom | 2013 MX-5 in Copper Red Mica | 2000 Corvette Convertible | 2010 Corvette Grand Sport | 2006 Audi A3 Turbo | 2008 BMW 328i |
10-13-2014, 07:47 PM | #11 |
10-13-2014, 08:05 PM | #12 |
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV Join Date: Feb 2013
10-13-2014, 08:25 PM | #13 |
I've worked under jackstands so much I don't even think about it anymore.
10-13-2014, 08:27 PM | #14 |
Drives: Silver 1LT 2011 camaro Join Date: Jul 2011
Buy rhino ramps from walmart. Return when done.
