05-26-2010, 10:27 PM | #1 |
Drives: 2010 Camaro SS RS Join Date: May 2009
Launching on DRs
I just bought a set of DRs for my 585 rwhp / 565 rwtq M6 camaro SS. I've seen a lot of A6 running DRs with a lot of HP and the stock halfshafts without any problems. What I would like to know is if there are any guys here running their M6 camaros with similar rwhp and tq at the track. I can't wait to get my tires but I'm a little afraid of what could happen to my halfshafts (rear axle) if I launch the car too aggressive. If any of you guys are running a similar set up with stock halfshafts please let me know what are you guys doing to launch the car effectively and safe with DRs.
Thanks!!!
Maggie TVS 2300 SC with a 3.6" pulley.
ZR1 Twin Disc clutch. Hurst Short Shifter. 1 7/8" ARH LT with highflow cats. Drive Shaft safety loop Roto-Fab CAI 160º Tstat. Stage 2 Snow Meth kit safeinjection. ADM Dual Pump kit ADM boost and AFR guages Catch Can. 586 RWHP/ 565 RWTQ Installed at Lethal Performance San Antonio www.youtube.com/cgarza12 |
05-26-2010, 10:30 PM | #2 |
Drives: 2010 Camaro Join Date: Feb 2010
6K and dump the clutch! Oh yeah, you should probably hold on too. Gd thing I'm auto. To much to worry about with a stick car. I can't wait to see the improvement.
And more importantly your wheels/tires departed CT yesterday at 10:10. Thats the latest update. |
05-26-2010, 10:39 PM | #3 | |
Now what about the drive shaft U joints, or bolts... has anyone had problems with those...?
05-27-2010, 08:59 AM | #4 |
Drives: 2011 Silverado, 2011 2SS/RS Conv Join Date: Dec 2009
Subscribed, and very interested to see what the replies are.
06-20-2010, 01:10 PM | #5 |
Drives: 2010 Camaro SS Join Date: Dec 2009
For anyone interested...
Here's what happened to my passenger side halfshaft after only 15 passes at the track:
This was using Launch Control with 18" MT drag radials. |
06-20-2010, 11:30 PM | #6 |
Drives: 2010 camaro ss/rs Join Date: Dec 2009
06-21-2010, 09:46 AM | #7 |
Hey Subfloor, what kind of mods do you have other than the MTs??
06-21-2010, 01:44 PM | #8 |
NuptualNemesis
Drives: Silver 1SS M6 - 480hp 11.57/120.79 Join Date: Jul 2009
Drive it out of the hole. If you don't smell the clutch it is not over slipping. Don't dump the clutch except on wet pavement for the burn out. You might want to upgrade the front and rear drive shaft bolts (industrial bolt supply company) and make sure they all have loctite. I sheared my rear bolts at the thread where they screw into the yoke. Caused damage to drive shaft. They did not have loctite and may have been loose.
Never spin the tires in first or second with traction control on. It will apply the brakes hard to stop the spin. |
06-21-2010, 08:22 PM | #9 |
Drives: 2005 Mustang GT M5 Join Date: Nov 2009
i have about 25 drag radial passes on my car, launching at 4k ish, no issues
2005 Mustang GT
JLT2 CAI, Brenspeed 93 tune, Boomtube Axlebacks, Lowering Springs, Lakewood Panhard bar/brace.......296 RWHP/315 RWTQ 12.883@106.56 |
06-21-2010, 08:38 PM | #10 |
06-21-2010, 09:50 PM | #11 |
Romanian Outlaw
Drives: 13 ZL1 , 14 Silverado Crew Cab Join Date: Apr 2010
Wonderin myself wit jus a few bolt on if it ok ta launch at 4k
[/SIGPIC]2013 Camaro ZL1 M6
06-21-2010, 11:04 PM | #12 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
I would highly recommend you not dump the clutch on stock shafts. DR will hook very hard compared to street radials and you most likely going to snap an axle. I would suggest loading it around 3500-4000 and slip it out and then hit WOT once it is out of the hole. If you get any wheel hop at all, instantly push in the clutch and get out of it or it will be the last pass. Get you some axles and then you can launch as hard as you want.
06-22-2010, 10:48 PM | #13 |
Drives: 2010 SS/RS CAMARO Join Date: Aug 2008
dont dump it tore the output shaft out on nittos extreme. slip at all times
IOM 2 SS/RS LS3 vin9862
06-23-2010, 12:49 AM | #14 |
Drives: 2010 camaro RS/SS Join Date: Jun 2010
I have broken my half shaft to and i am bone stock with the stock tires lol but mine didnt break from the launch it broke from the shift from first to second at 6500rpm i was going 35 mph when it poped
Similar Threads | ||||
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3652 | 08-17-2023 02:50 PM |
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 10:40 AM |
Any modded 5th gen SS's here that outrun a stock C6Z? | thebrander | 5th Gen Camaro SS LS LT General Discussions | 9 | 05-15-2010 04:23 PM |
How are you guys launching?? | mtm864 | Dragstrip and Launch Techniques Discussion | 1 | 04-20-2010 01:53 PM |
TPMS on DR's | FASST 1 | Wheels and Tires Talk Sponsored by The Tire Rack | 3 | 04-13-2010 06:56 AM |
