11-09-2013, 08:39 AM | #1 |
Drives: 2012 Camaro 2ss 45th M6 Join Date: Jun 2012
Pics: Welds on the back
Stock ride height, w no mods (2012 SS) zero clearance issues, didn't even have to zip tie the ebrake cable...
11-09-2013, 08:46 AM | #2 |
Only thing I'm not too fond of is how the edge of the outer lip on the wheel sticks out probably a 1/4" as you can see.
This is with Mickey Thompson 295/45r17 ET Street I I drag radials... Thinking I should have went w a 315/35r17 since I was wanting a shorter Tire anyways... Everyone else's have this same issue on other tires?? |
11-09-2013, 09:52 AM | #3 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
What width wheel?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
11-09-2013, 10:35 AM | #4 |
17x10
11-09-2013, 11:38 AM | #5 |
Looks good!!! I didn't have that problem with the wheel lip on mine, but I was running the 325/45.
11-15-2013, 12:14 PM | #6 |
"NY5THGEN"
Drives: Blk on Blk 2SS/RS M6 Join Date: Sep 2010
Yes, I have the same problem. I have the M/T et street bias ply tires on 17x10 rims. And I don't like it. That was the first thing I notice, when I had the tires mounted.
2011, 2SS/RS, Blk on Blk, M6, CAI cold air intake, MGW shifter, Pfadt sway bars, & lowering springs, AAC led's DRL, dome, trunk, lic plate, Lloyd's custom mat's, Bowtie delete, DRL harness.
11-15-2013, 09:30 PM | #7 |
chevy pride
i ran the 35 in the 18" vs the 45. and i love it . help the car alot in the first 60'
check out ky speeds fb page https://www.facebook.com/kyspeed |
11-16-2013, 05:49 PM | #8 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Love the look of a meaty tire.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
