09-28-2015, 12:56 PM | #1 |
Drives: 2013 ZL1 416 Join Date: Feb 2013
2013 1le Complete Center Console
For sale 2013 Complete Center Console came with a 1le recaro seat purchase I made
I have enough parts to make this anyway you want SS stone stich or ZL1 red stich cnd or usa gauges M6 or A6 $260 shipped Last edited by Blownfogger540; 11-20-2016 at 08:07 PM. |
09-28-2015, 07:16 PM | #2 |
S1N1STR
I'd like to have the 4 gauge bezel if you decide to separate.
09-28-2015, 09:18 PM | #3 |
look in my other adds
09-29-2015, 07:53 PM | #4 |
Honestly though what level of difficulty is the install into a car that does not have the cluster?
K & N Cold Air Intake, 25% window tint, 2 sets of 6000K LED fogs added, bow ties delete, Pypes catback mid exhaust, MGP Caliper covers, Spyder projection HID 6000K lighting with dual CCFL halos, Technostalgia Rapid Fire LED Tail Lights, blacked out rear bezels, Oracle Ghosted side marker lights, Platinum Ultra Rims, LED tag, dome, trunk lighting, Razzi Ground Effects, Billet Grille, Oracle Concept Mirrors, Eibach Pro Springs,
GM Strut Tower Brace and LED lit door sills. |
09-29-2015, 09:03 PM | #5 |
09-30-2015, 07:42 PM | #6 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I thought 6 speed cars had the shift pattern on that bezel?????
09-30-2015, 08:48 PM | #7 |
they do
10-03-2015, 10:37 AM | #8 |
Ttt !
10-03-2015, 12:53 PM | #9 |
Drives: Summit White LFX Join Date: Dec 2013
10-03-2015, 01:30 PM | #10 |
doesn't really mater what car it came from ss zl1 1le as long as it has the gauges u want and or M6 or A6 bezel u need
I can change it out to the buyers preference was just saying the recaro's I bought came from a 1le and this came with it |
10-04-2015, 03:42 PM | #11 |
Banned
Drives: 2015 Camaro 1LT Join Date: May 2010
4 Gauge cluster.
It is very easy to install. Take a wide plastic trim tool and put it between the console and the shifter trim plate and pry up and work your way around the shifter trim plate, you may have to move the shifter back to get it out and unplug the harness. I think you will have to buy a harness from GEN5DIY.COM about $80.00. and it is plug and play harness. On my 2015 Camaro I had to buy the harness. It plugs in behind the passenger kick panel then fish the wire harness from the kick panel to the center console and that's it. You will have to remove the old cigarette lighter and the traction control button and put it in the new trim plate. When I bought my 4 gauge cluster with trim plate for my 2015 Camaro it had the cigarette lighter and traction control button with it.
10-06-2015, 05:25 PM | #12 |
Do you have a good M6 bezel???
10-06-2015, 06:33 PM | #13 |
look in the other add I have
10-09-2015, 12:31 AM | #14 |
Drives: 2012 camaro 2LS Join Date: Aug 2015
Hey I think this 4 pack gauge will definitely fit my LS if you ever want to take it apart from the rest of the console let me know and I'll buy it from you. Thanks.
Sent from my SAMSUNG-SM-G900A using Tapatalk |
