Old 07-14-2018, 10:44 PM   #1
str8wick3d
Drives: 2011 Camaro SS
clutch overheat? also trouble nailing this 60ft
So my last pass of the night had a good 60ft going and then when I grabbed 2nd the car would not go passed 45mph..like it was hitting an invisible rev limiter and bouncing off it. Also there was a horrible clutch smell. I hot lapped it like a dumb ass cause the run before my 2step didn't activate. (mix matched my 1000 and 100 settings) Was it just to hot? Seemed okay on the way home and it wasn't the 2 step getting stuck cause I tested that again to.
Also with these 60foots.. I am running the et streets radial not the pro or r. I have tried different psi,different 2step settings, different burnouts and cannot do better than 2.0. Am i fighting a losing battle with the stock gears and the big cam? I think my sweet spot is leaving at 3k rpm but still think it should be alot better number for a big cam car. Anything over 3k blows the tires off completely. Even at zmax on a prepped track last weekend
str8wick3d is offline   Reply With Quote
Old 09-04-2018, 06:17 PM   #2
DARKTHIRTY777
DARKTHIRTY777's Avatar
Drives: 2011 camaro ss
I have been trying to get my 60' lower as well. The best I got was a 1.81. I have my 2 step at 2500 rpm and slowly let off the clutch. I was having issues with my shift light so my time was not where I want it. I figure with more tra ck time it will improve. I have 18" zl1 replicas with Hoosier drag radials. The rim is spinning in the tire. Maybe time for some beadlocks.
2011 ls3 ss/rs, Kooks long tube headers, gutted high flow cats, 231/239. 624" lifted squared 115+3 lsa comp cam, ecs supercharger, Alky methanol kit, DSS 1000hp axles, BMR toe rods, BMR trailering arms, Fore innovations dual fuel pump. Flex fuel sensor and 360 custom tunes, hp tuners NGAUGE. 752 hp with 93 octane and 825 hp with E85.
DARKTHIRTY777 is offline   Reply With Quote
Old 09-06-2018, 05:18 PM   #3
str8wick3d
I have the 4.10s installed now first test hit tomorrow
Old 09-06-2018, 10:12 PM   #4
GR8WHITE1
GR8WHITE1's Avatar
Drives: camaro
Originally Posted by DARKTHIRTY777 View Post
I have been trying to get my 60' lower as well. The best I got was a 1.81. I have my 2 step at 2500 rpm and slowly let of the clutch. I was having issues with my shift light so my time was not where I want it. I figure with more tra k to me it will improve. I have 18" zl1 replicas with Hoosier drag radials. The rim is spinning in the tire. Maybe time for some beadlocks.
Roughen up the inside of the rim where the bead sits. Mount the tires but don't inflate. Apply permatex high tack and then air up the tires. You won't need beadlocks.
Sent from my SM-G930P using Tapatalk
GR8WHITE1 is offline   Reply With Quote
Old 09-09-2018, 09:19 AM   #5
DARKTHIRTY777
I will have to try that Gr8white1. Thanks
