09-20-2018, 11:53 AM | #1 |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
Better 60'
How do people cut 1.2 and 1.3 60's? I am cutting 1.4 60's on my 2015 1LE. I realize suspension and wheel setup is key, so here is mine:
17x10 weld s71 rear Mickey Thompson et street R's 305/45/17 18 psi 1.44 60' average RPM stage 5 4L80e w precision vigilante 3400 converter ZL1 3.73 differential DSS aluminum one piece driveshaft BMR suspension Viking Crusader double adjustable shocks in rear Do I need to add more power or is it mainly weight related? Maybe a 15" conversion? Car makes 700whp and weighs 4160 with me in it. Any help or suggestion is appreciated. |
09-20-2018, 02:45 PM | #2 |
Drives: 2013 SS Join Date: May 2013
To achieve a 1.20 60ft in a 5th gen is going to require A LOT more power. Some suspension work will get you some 1.3X 60fts.
09-21-2018, 08:36 AM | #3 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Thats my best 60' i have a 4l80 with a 3600 stall and a 3.73 zl1 diff. I need higher stall. Your lsa has better low end torque than my centrifugal but you may need more stall also, 4l80 has a tall 1st gear. Do you spin at all?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
09-21-2018, 10:22 AM | #4 |
Trouble_SM
No spinning that I can see. I will try to load a video.
09-21-2018, 08:35 PM | #5 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Leave on more power.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
