06-19-2016, 09:41 PM | #1 |
GuitarmageddonZL1
Drives: 13 ZL1, 17 TT ZL1, 17 Silverado Join Date: Feb 2015
Recommended oil for ZL1
I'm getting ready to do a decent build on my ZL1 (pulleys, injectors, HX, cam, etc) and my installer is going to change the oil for me. What do you guys recommend putting in? Should I put in what the manual says or should I go with something different?
06-19-2016, 09:49 PM | #2 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
I have used Mobil 1 from the start as well as many others here. And remember it is 8 qts. Costco has sales on Mobil 1 $27.99 for 6 regular $37.99. I think you will get a lot of opinions as far as brand. I think more important to meet the manufacturer specs.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
06-19-2016, 09:53 PM | #3 |
Too much is never enough!
Another oil thread.
Personally I run Joe Gibbs DT40, but I have a built engine, the tolerances are different from a stock engine. In the past I have run Royal Purple, won't be running that anymore (not the best for turbos) Mobil One, and Valvoline VR1 synthetic racing oil. I would recomend either Joe gibbs LS30 if your engine is stock, Amsoil, and Valvoline VR1.
06-19-2016, 11:22 PM | #4 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, 22 Ram 2500 Join Date: Apr 2015
I run amsoil 5-30 signature
06-19-2016, 11:25 PM | #5 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
10w30 Amsoil Signature series works well and my car liked it. Joe Gibbs LS30 does a great job of running clean, cleanest oil I ever ran. I am not a fan of the shelf oils not even Mobil 1. Also you'd be surprised to see how many oils even at thicker weights Joe Gibbs LS30 out performs.
06-19-2016, 11:34 PM | #6 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
For oil choices, go here first: https://540ratblog.wordpress.com/201...-test-ranking/
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
06-20-2016, 07:15 AM | #7 |
Drives: 2016 Corvette Z06 Blade Silver Join Date: Jun 2009
The changes you are making are not changing the physical engine hardware. I would run Mobil1. Even GM's new Hi-Po cars call for it.
Great oil and what the motor was designed to use.
2016 2LZ Z06 Blade Silver
2013 ZL1 BLACK on BLACK <SOLD> Roto-Fab CAI 2010 2SS/RS BLACK on BLACK <SOLD> 3" MBRP 304 Stainless Exhaust Roto-Fab CAI |
06-20-2016, 07:43 AM | #8 |
Drives: 2014 ZL1 Join Date: Sep 2012
I have injectors, lower pulley, headers and a couple other little things. I have been running Joe Gibbs LS30. Seems like good stuff.
06-20-2016, 07:58 AM | #9 |
Drives: '12 SIM ZL1, 1 of 49 Join Date: Sep 2011
I run Amsoil 5w-30 Signature Series. I've been using Amsoil in all our vehicles for 30+ years. One a FZJ80 Land Cruiser has 380,000+ miles on it.
Under Hood - Painted strut bar ends w/custom Polished Stainless mounting hardware, E2 CC, RotoFab CAI, ZL1 underhood decal, Amsoil oil, Black billet strut covers, Metco pulleys, intercooler reservoir, JRE 75 RWHP package.
Chassis - Hawk ceramic brake pads, ZL1 wheel decals, Amsoil fluids Interior - A pillar gauge pod w/Aeroforce Interceptor gauges, Polished ZL1 speaker rings, ZL1 mats and console lid, Custom GPS mount Exterior - 3M clear bra, LED driving lights, PIAA Plasma Ion yellow fog lights, Window tint, CF bowties, Technostalgia sequential tail lights |
06-20-2016, 08:10 AM | #10 |
GuitarmageddonZL1
Seems like most of you are running Amsoil and Joe Gibbs. I may have to try one of those instead of Mobil 1
06-20-2016, 08:36 AM | #11 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
I'm currently using Pennzoil Ultra Platinum but I've had the free dealer service oil changes up until recently which is with Mobil 1.
Swift....Silent....Deadly
06-20-2016, 02:42 PM | #12 |
KaBoom1701
I run Mobile 1. No issues
Mods:
06-20-2016, 04:24 PM | #13 |
Z-BEAST
Drives: 2013 JDP ZL-850 Track Spec ZL1, Join Date: Mar 2013
Driven racing oil LS30 Joe Gibbs
Designed for high performance LS series engines. Utilizes advanced synthetic base oils to provide high temperature and high shear protection. Ideal for LS based "crate" engines and supercharged LS performance engines. Oil made for the LS motors. This is what my engine builder uses and recommends. Last edited by owhite3003; 07-06-2016 at 05:09 PM. |
06-20-2016, 05:16 PM | #14 |
Go fast, please.
