08-17-2014, 02:15 PM | #1 |
Drives: ZL1 Join Date: May 2012
Front splash guards won't adhere
I'm using the recommended 3M 6930 body molding tape and prepping both surfaces with alcohol. They will not stay stuck to the fender. I really don't want to use the clips. Anybody care to offer any different products or methods that have worked to help these things adhere?
Thanks!
2014 BRM ZL1 #229
Rotofab, VMax, Moroso, MGW I used to be schizophrenic, but we're okay now. |
08-17-2014, 03:33 PM | #2 |
Where am I?
Drives: Zoe the ZL1, 2012 Frontier Join Date: Apr 2011
I used 3M Advanced Super Strength Molding Tape. Item number 03614.
It's got a red backing on the tape and the package has a green stripe across the top and a white 2 with a green background in the upper right corner. I fully prepped each surface by rubbing down with the purest rubbing alcohol I could find (99.8%) and it's held firm for two years. It's important to put the tape on the fender first, with the red side facing out then pulling off the red backing as you move up. The directions state which side should be attached to the plastic and which should be attached to the metal. It's also important to press firmly for several seconds/minutes as to ensure a good strong bond.
FOR SALE: 2013 ZL1 Message me if interested |
08-17-2014, 06:13 PM | #3 |
Drives: 2015 ZL1 Join Date: Jul 2014
I used 3M extreme that I bought at lowes. They've only been on two days but no issues yet.
2015 ZL1 #117
Summit White M6 |
08-21-2014, 06:38 AM | #4 |
Drives: 2013 ZL1 Join Date: Apr 2012
Ditto and mine have been on 5 months and I wash the car with a power washer. They are holding very well.
Past Camaros: 1970 SS 350, 1984, 2012 2SS/RS Vert; Vettes: 1993, 2004 Vert; 2008 ZO6
