10-16-2014, 07:21 PM | #1 |
Drives: '21 ZLE A10 Join Date: May 2012
Lowering spring install tips from a shadetree mechanic
I just installed the Eibach spring pro kit on my car. It sits great now and the ride is fine too. I have a few tips and tricks for people that the instructions conveniently leave out. I did this in my driveway with no lift and two floor jacks. Overall, the front springs are way easier to change than the rears. I will start with the front springs since they are easiest. You need a 24 mm socket and adjustable wrench preferably with an air impact to loosen the strut bolts. Also have an 18 mm open end ratcheting wrench with a 8mm open end wrench for the sway bar top link which attaches to the spring assembly. Remove the wheel speed sensor wire and 10 mm nut where the brake line attaches to the strut. Make sure the car is jacked by the body preferably at the pinch weld with a jack pad. Use the second floor jack to take pressure off of the strut and spring assembly before removing the sway bar top link. After the sway bar top link is removed, you can take the pressure off of the strut and spring assembly. Then, remove the 24 mm strut bolts and associated nuts. Then go under the hood and remove the 24mm top nut and the whole assembly can be removed. Swap out the old spring with the new spring paying careful attention to the clocking of the springs in the mount. Reinstall just as you removed everything. Use the second floor jack to compress the spring assembly then reattach the top swaybar mount. The rear is much more involved because of the magnetic ride wire that has to be depinned. The top part of the spring assembly is held with 4 15mm bolts one of which cannot be removed with a socket wrench easily. Use a 15 mm ratcheting wrench in this location. The shock mount bolt is 21 mm and the lower control arm bolt which needs to be removed is 18 mm. The swaybar link has a 15 mm nut on top and a 15 mm head on the lower part of the control arm. Once the car is raised using the pinch weld, use your second floor jack to take pressure off of the assembly so it is not hanging free because the control arm is under a lot of spring pressure. Remove the swaybar link first so that pressure is relieved. Next, remove the top 15 mm bolts holding the spring assembly to the body. Lower the floor jack then remove the 21 mm shock retaining nut and lower control arm 18 mm bolt and nut. Make sure to disconnect the weather pack connector at the top of the shock and also remove the magnetic ride sensor from the frame which is held with a single 10 mm nut. Remove the entire assembly and proceed to the most difficult part of this whole procedure. The wires going to the magnetic shocks must be unpinned from the weather pack connector in order to remove the top nut of the spring assembly. Look into the connector and you will see a purple secondary retainer. You must remove this first which isn't easy. I used a small pic and a thin pair of long reach needle nose pliers to remove the purple connector. Getting the pins to release from the weather pack connector after this purple connector is removed was not the easiest thing either. One of the posts from vendor suggested using a depinning tool for removal of the pins which I found to be impossible. The release for the weatherpack pins is up and over a little plastic shelf so I used a bent paperclip to release the pin for removal. Good luck using the release tool which is perfectly straight. All of this after the black plastic elbow is removed of course. Reinstall everything as you removed and make sure you pay attention where the new spring is clocked. Here are a few pics which may help. I also did this procedure solo and it was no problem.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold) '15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold) '12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold) Last edited by Stephen12ZL1; 10-17-2014 at 10:25 AM. |
10-16-2014, 07:29 PM | #2 |
tools...look at paper clip
10-16-2014, 07:30 PM | #3 |
Car on jacks. I actually have 3 floor jacks.
10-16-2014, 07:32 PM | #4 |
depinned connector wires
10-16-2014, 07:35 PM | #5 |
After
10-17-2014, 06:08 PM | #6 | |
Drives: Camaro Join Date: Aug 2013
We just installed BMR 1.25" drop on my ZL1. (see my recent thread)
http://www.camaro5.com/forums/showthread.php?t=261203 P.S. Holy shit did you go to school?! Grammar, punctuation, and paragraphs go a long way. This is a big blob... Let me fix it for you.... Quote:
10-17-2014, 07:41 PM | #7 |
Drives: 2013 ZL1 Camaro 2000 SLP Camaro Join Date: Oct 2012
Good write up Stephen. Guess we will be doing mine next. Lol
10-17-2014, 08:14 PM | #8 |
Drives: 2013 ZL1 Join Date: Oct 2011
I went to school at yardale where a I had a 4.0 grade average and there I learned to tell the grammar police the following.
b e l oving o pen w ith m y e motions ha ha. PS I am just bored and having fun.
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
10-17-2014, 08:24 PM | #9 | |
10-17-2014, 08:47 PM | #10 |
Thanks Hognutz. Wow...I didn't consider the "grammar police" invading my post, but I do see my errors. How many posts does Mr. Police have here...107 big ones??
10-18-2014, 10:40 AM | #11 | |
This is fantastic.
Laus Deo
10-18-2014, 02:11 PM | #12 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Nice Stephen! I'm most curious if this makes any difference in your 60 foot times. I would have done it long ago but I can barely get my car on and off a trailer now... and my spoiler already scrapes on the end of my driveway....
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
10-18-2014, 03:43 PM | #13 |
Drives: none Join Date: Aug 2011
10-18-2014, 06:42 PM | #14 |
Unfortunately, I would guess that my 60' may suffer because the new springs may affect weight transfer. Of course, I will run soon when time & weather permits.
