03-11-2015, 04:41 PM | #1 |
Too much is never enough!
Boost PID is showing half of gauge reading in HPT
I want to log boost in HPT, I know this is kinda an easy remedial topic, I have searched and all I can come up with is the PID to do it, not topics for the readings being off.
I setup my PID using [PID.11.PSI]-14.5 But like the title says, my boost gauge will show -20 and my datalog will show like -9 or close that +/- a few. I am running a 2 bar operating system, and using a AEM Tru Boost for my Gauge. Any help will be appreciated, and thank you in advance for reading.
03-12-2015, 08:20 AM | #2 |
Geek
Did you rescale your MAP when you activated the custom OS?
edited Oh I see you're already up and running with an FSP tune. I thought you were just experimenting for some reason.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
03-12-2015, 10:10 AM | #3 |
Yea, the tune is scaled, I was wondering if there was a way or need to rescale it in the scanner.
I can post a config and datalog if needed.
03-13-2015, 03:29 AM | #4 |
Bump, someone has to know this, or have experience with it.
03-15-2015, 03:14 PM | #5 |
I found that I didnt have a 2bar MAP sensor selected in my table display. I deleted the std map sensor and am trying to install the AUX 2bar MAP sensor. Now its an unsupported parameter. I am using [AUX.20021] exactly to "configure user defined"
What am I missing?
