09-16-2010, 07:45 PM | #1 |
Line lock and launching
I have been to the track a couple times and made roughly 10-15 passes. My best time was last night with a 13.6. My launch and 60' are killing me. My 60' was 2.3. So I am thinking about getting line lock to help me with launching(hopefully). My main question is with line lock once I'm staged and ready to go, I engage line lock, then I'm wondering if i let of the clutch completly and hold the RPMs around 2K would that help? Is it even possible? What harm would I be doing to my car? I go to the track about once a month, so it's not like I would be doing it everyday. Below is the video of my 13.6 run. As you can see I bogged it really bad off the launch.
Black cars are not hobbies, they are an obsession |
09-16-2010, 08:32 PM | #2 |
No, line lock will hold you some, but not with clutch fully released.
09-16-2010, 08:37 PM | #3 |
aka Patrick
Line lock basically applies the brake to front brakes. So if you press the brake all the way down with clutch fully released... that's how it would act.
And yes, your 60ish foot looked horrible in that video, hopefully some manual guys can toss in some words of wisdom
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft |
09-28-2010, 09:29 PM | #4 |
Drives: CGM 2SS RS w/ white stripes Join Date: Jul 2008
Yeah, you'd break the light sensor and get the red light if you tried that. I don't think they'd like the idea of you doing that even if somehow you didn't trip the sensor. But don't look to me for launch advice. Your 60' times are probably better than mine. I haven't even been to a track in a few months :(
09-28-2010, 09:34 PM | #5 |
Prefer to be blown!
Drives: 2010 Silver/Black 2SS/RS Manual Join Date: Mar 2010
Get some drag radials. I ran with mine last week and got a 1.9 60' and my best time of 13.23 in the 1/4. The drag radials still need to be warmed up in the water box or with line loc. You can also use comp mode, just be careful during your launches with releasing the clutch, the rear axles are on the weaker side. The drag radials are not good for a daily driver so I recommend that you get a second set of tires. What tire pressure were you running in the rear? I run 20 PSI in the drag radials.
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
10-01-2010, 12:44 PM | #6 |
Drives: 2010 CGM CamaroSS Join Date: May 2009
Drag radials are a must to get those 60ft times down. I have used the Nitto 555r and the best 60ft so far was a 1.690 with 20psi in them. I have a set of MT radials I will be tryingout next week. I would recommed getting a line lock since this will help you get a more consistant burnout. As for the actual launch of the car you will need to experiement with different rpms and techniques until you can figure out what your tire and suspension likes. You may want to contact Lingenfelter about their 2-step.
Sam |
10-01-2010, 01:03 PM | #7 |
BAMF SS
I would look into a two step, before a line lock, if you are looking to improve your 60' times. A line-lock will not help your 60' on a proper track (in a manual that is).
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
10-01-2010, 02:05 PM | #8 |
I kind of know what a two step is, but could someone explain a little better or point me in the right direction?
10-01-2010, 02:18 PM | #9 |
BAMF SS
think of it as a temporary 2nd rev limiter.
You have it hooked it up to a momentary button. Hold the button down, and floor the gas pedal, and your engine will be (spark limited) to a certain RPM. That way, each pass, you are launching at the same exact RPM. If you bog, turn the RPM up, if you spin, turn the RPM down. When you want to go, let the clutch out and let go of the button. It especially helps out FI cars, as it helps them build boost off the line.
10-01-2010, 02:57 PM | #10 | ||
I will caution you, if you car has catalyst, you will not want to install this device. Feel free to contact me if you have any questions about this device. |
10-01-2010, 03:39 PM | #11 | ||
10-03-2010, 02:19 PM | #12 |
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS ) Join Date: Nov 2009
Is it related to catalytic conversion?
10-03-2010, 02:25 PM | #13 | ||||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
With a line lock on a manual, it helps out a lot when doing your burnouts, but you've got enough things to keep track of when you are launching a manual that you dont need to remember to disengage the line lock at the launch. Quote:
GM installed one of these in the V8 M6's from the factory. its called Launch Control
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
10-03-2010, 02:35 PM | #14 | |
BAMF SS
On a decently prepped track with any kind of decent tires, a 2000 rpm launch will more than likely bog the car.
